03-14-2008, 05:38 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Beside U Age: 37
Member: 647414 Status: Offline Thanks Meter: 127 | Dis is the Prosedure For unlocking first, download latest version, select USB as interface. that is REQUIRED. select phone model settings - check ONLY "use server for csca unlock/flash", "do full unlock instead of usercode reset", fill your login details. back to semc tab, press unlock, attach phone with pressed "C" buttons. if you have enough credits - you will receive next message "SIGNATURE QUEUED FOR CALCULATION, CHECK BACK LATER" (that means signature is added to calculation queue. calculation can take up to 3 days. if after 3 days (72 hours) signature will NOT be calculated - credits will be automatically returned when you press "info" or add another phone to queue.) (if you receive next message "QUEUE FULL, CHECK BACK LATER", that means all slots for calculations filled up and you need try again later) Code: It seems obvious that many amongst us do not understand plain English, or the phrase "QUEUE FULL, CHECK BACK LATER". Lets start with a 'QUEUE' - a long line of people one after another, all standing in line waiting to do something in this case add a phone to the server to start the process of unlocking. 'FULL', obviously means the maximum, no more, 100% or chockerblock (sorry English phrase). Add both these words to together you get 'QUEUE FULL' and we get a long line of people waiting or 'queuing' with no people allowed to join this queue unmtil the first person in line leaves the queue. Are we getting there yet.... (retards simply nod your head at this point ) Now "CHECK BACK LATER", means "try again soon", "try in a few minutes", "try in an hour", "try in the middle of the dark dark night when its very scary", you get my point now surely. So there you have it for those "people" who don't quite understand what "QUEUE FULL, CHECK BACK LATER" really means...... call it an idiot's guide. (NOT each 5 min , but each 60 min ) if signature is calculated - you will receive 'SUCCESS' response, otherwise you will receive "%YOUR_IMEI% ALREADY IN QUEUE" - that means signature is in calculation queue. if calculation is success, then signature will be saved in backup\%imei% folder in your setool2 directory. next, backup will be created so you will be able to restore phone if something will go wrong (hardly believe, but who knows...) next, you will be prompted to detach phone and turn it on. do so. detach phone. turn it on FULLY phone will be on 5 locks, that is normal. connect phone to usb. if phone will ask you switch to phone mode - switch to phone mode. it can ask you for drivers,if you not installed them previously. install all needed phone drivers (phones.rar on support area) be SURE that you install all drivers correctly. press "testpoint ok" note: in latest setool2 version phone will be searched constantly on all available comports until it will be found. So, you not need to press "TESTPOINT OK" procedure will continue,phone will be switched off and unlocked. remember, if something will go wrong - you have a backup of security units. cost of DB2020 unlock is 10 credits. it divided into 2 steps: signature calculation 6 credits (charged once), phone unlock - 4 credits (charged once, if by accident, server is recharging while you executing unlock, credits NOT charged) as usual, credits will NOT be recovered in case of connection failures. (error 10054,10060). that is NOT terms for discussion. NOTE! there is STILL REMAIN USERCODE RESET FOR DB2020/DB2012/PNX5230. it will work, if you UNCHECK option "do full unlock instead of usercode reset" and press UNLOCK. note: i STRONGLY recommend you to instal PHONE drivers BEFORE starting unlock procedure Best Regard WinD |
The Following User Says Thank You to WinD_VteC For This Useful Post: |
can cruiser ultimate unlocker unlock 5lock close in k510,k320,w850 and others | segun4u | Cruiser Suite | 2 | 08-19-2009 13:29 |
K320 5Lock Close DONE by SETOOL via TP | rico_deep | SETool2 | 21 | 03-28-2009 12:04 |
K320 Cid50 5lock closed | yousaf22us | DreamBox | 2 | 08-11-2008 11:08 |
k510 5lock | NADEEM GONDAL | FuriousGold | 0 | 03-12-2008 06:49 |
c62 5locks closed | tatalko | NON Siemens Brand (ODM Phones) | 6 | 04-22-2005 17:35 |
