08-28-2010, 21:21 | #1 (permalink) |
Insane Poster Join Date: Apr 2008 Location: Turkey
Member: 748956 Status: Offline Thanks Meter: 1 | k550 is dead after recovery.. try the flash cid 49, full completed but not powered. it's LOG here SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101111110000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35601901524264 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "J:\gsm\s.eric\SETOOL3\Sonyericsson\FLAŞLAR\k550\c id-49\K550_R1JD001_MAIN_GENERIC_LI_CID49_BROWN.mbn" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "J:\gsm\s.eric\SETOOL3\Sonyericsson\FLAŞLAR\k550\c id-49\K550_R1JD001_FS_EUROPE_2_CID49_BROWN.fbn" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 3460 Will flash 173 blocks... No situable fsloader found, exiting Elapsed: 719 secs. its flash file cid 49.. ---------------------------------------------- this log is other cid flash file.. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101111110000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35601901524264 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "J:\gsm\s.eric\SETOOL3\Sonyericsson\FLAŞLAR\k550\c id51\R1JD001_1250669_GENERIC_LI.ssw" CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 7 secs. how to power this phone? help please.. thanks |
08-29-2010, 16:14 | #8 (permalink) |
Member: 748956 Status: Offline Thanks Meter: 1 | it identfy LOG.. LOG is here... CFG:000100000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35601901524264 CERT:N/A FLASH CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 40 secs. please help me |
08-29-2010, 16:28 | #9 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,440 | Follow carefully these easy steps that is so-called reset procedure. 1. go to Emptyfill and Repair tab 2. select K550 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 6.1.stay working on Emptyfill and Repair tab 7. add to firmware area %SeTool%\gdfs_in_ssw_format\db2020\k550_gdfs_SSW.s sw 8. add to firmware area %SeTool%\eroms\db2020\DB2020EROM_CNV_RED49_BROWN_C ID49_DB2020.ssw 9. press flash 10. Reflash phone with RED cid49 firmware. skip steps 3,4,5 for further help install www.teamviewer.com and drop to me a private message |
The Following User Says Thank You to :Aishur: For This Useful Post: |
08-29-2010, 17:24 | #10 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,440 | oops lack of cid49 firmware please replace step 8 and 10 by 8. add to firmware area %SeTool%\eroms\db2020\DB2020EROM_CNV_51_BROWN_C ID49_DB2020.ssw 10. Reflash phone with RED cid51 firmware. |
08-29-2010, 18:44 | #11 (permalink) | |
Member: 748956 Status: Offline Thanks Meter: 1 | Quote:
CFG:000111110000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35601901524264 CERT:RED FLASH CID:49 COLOR:RED Bypass loader not responding ! Elapsed: 9 secs. | |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? | telefonman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-13-2000 20:06 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
