Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 08-08-2008, 03:19   #1 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
>>> K610i damaged GDFS successfully repaired <<<
Just O N E TRY in stage 1
Just O N E TRY in stage 2
8/8/2008 9:54:21 AM v0.914037/UNI
8/8/2008 9:54:21 AM CARD SERIAL: >>> K E A E L I T E <<<
8/8/2008 9:54:21 AM Loaded 51 flash de******ors
8/8/2008 9:57:49 AM TESTPOINT REPAIR STAGE #1 STARTED
8/8/2008 9:57:49 AM Open COM port OK
8/8/2008 9:58:34 AM ChipID:9900,EMP protocol:0301
8/8/2008 9:58:34 AM Speed:921600
8/8/2008 9:58:35 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A
8/8/2008 9:58:35 AM FLASH CID:52 COLOR:RED
8/8/2008 9:58:36 AM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
8/8/2008 9:58:36 AM PREPARING...
8/8/2008 9:58:43 AM ATTACH TP #1 AND PRESS "READY"
8/8/2008 10:05:18 AM RELEASE TP #1 AND PRESS "READY"
8/8/2008 10:05:20 AM TP #1 LOOKS OKAY
8/8/2008 10:05:28 AM DONE
8/8/2008 10:05:29 AM Elapsed: 460 secs.
8/8/2008 10:08:57 AM TESTPOINT REPAIR STAGE #2 STARTED
8/8/2008 10:08:57 AM Open COM port OK
8/8/2008 10:09:02 AM ChipID:9900,EMP protocol:0301
8/8/2008 10:09:02 AM Speed:921600
8/8/2008 10:09:02 AM ATTACH TP #2 AND PRESS "READY"
8/8/2008 10:09:18 AM Trying to launch embedded bootloader...
8/8/2008 10:09:18 AM TP #2 LOOKS OKAY
8/8/2008 10:09:18 AM RELEASE TP #2 AND PRESS "READY"
8/8/2008 10:09:22 AM INT LDRB2020_PRELOADER_FOR_SETOOL2
8/8/2008 10:09:25 AM WRITING EROM...
8/8/2008 10:09:28 AM DONE
8/8/2008 10:09:29 AM Elapsed: 32 secs.
8/8/2008 10:10:22 AM Open COM port OK
8/8/2008 10:10:25 AM ChipID:9900,EMP protocol:0301
8/8/2008 10:10:25 AM Speed:921600
8/8/2008 10:10:26 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A
8/8/2008 10:10:26 AM FLASH CID:49 COLOR:BROWN
8/8/2008 10:10:28 AM LDR:060721 1021 DB2020_SERVICE_LOADER
8/8/2008 10:10:28 AM Flash ID check:897E
8/8/2008 10:10:28 AM Flash props sent ok
8/8/2008 10:10:28 AM writing F:\SETool\v.0914037\gdfs_in_ssw_format\db2020\K610 _GDFS_SSW.ssw
8/8/2008 10:10:29 AM CURRENT FLASH FILE CID:49
8/8/2008 10:10:29 AM SSW uses complete hash, hash len is:640
8/8/2008 10:10:30 AM Will flash 32 blocks...
8/8/2008 10:11:03 AM SSW loading returns:0
8/8/2008 10:11:04 AM Setting up GDFS...
8/8/2008 10:11:04 AM OTP WRITE NOT EXECUTED.
8/8/2008 10:11:04 AM Writing simlocks...
8/8/2008 10:11:04 AM ALL UNLOCK/LOCK CODES SET TO "42867537"
8/8/2008 10:11:04 AM Signing...
8/8/2008 10:11:05 AM control keys complete.
8/8/2008 10:11:06 AM full sig complete.
8/8/2008 10:11:09 AM Elapsed: 46 secs.
8/8/2008 10:11:35 AM SIGNED MODE (USING SERVER).
8/8/2008 10:11:35 AM ALTERNATIVE SECURITY BYPASS ENABLED.
8/8/2008 10:11:35 AM Open COM port OK
8/8/2008 10:11:39 AM ChipID:9900,EMP protocol:0301
8/8/2008 10:11:39 AM Speed:921600
8/8/2008 10:11:40 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A
8/8/2008 10:11:40 AM FLASH CID:49 COLOR:BROWN
8/8/2008 10:11:42 AM LDR:060721 1021 DB2020_SERVICE_LOADER
8/8/2008 10:11:42 AM Flash ID check:897E
8/8/2008 10:11:42 AM Flash props sent ok
8/8/2008 10:11:42 AM writing F:\SETool\v.0914037\eroms\DB2020EROM_CNV_RED52_BRO WN_CID49_DB2020.ssw
8/8/2008 10:11:43 AM CURRENT FLASH FILE CID:49
8/8/2008 10:11:43 AM SSW uses complete hash, hash len is:40
8/8/2008 10:11:43 AM Will flash 2 blocks...
8/8/2008 10:11:46 AM SSW loading returns:0
8/8/2008 10:11:48 AM Elapsed: 13 secs.
8/8/2008 10:11:51 AM SIGNED MODE (USING SERVER).
8/8/2008 10:11:51 AM ALTERNATIVE SECURITY BYPASS ENABLED.
8/8/2008 10:11:51 AM Open COM port OK
8/8/2008 10:11:54 AM ChipID:9900,EMP protocol:0301
8/8/2008 10:11:54 AM Speed:921600
8/8/2008 10:11:55 AM Flash ID check:897E
8/8/2008 10:11:55 AM Flash props sent ok
8/8/2008 10:11:55 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A
8/8/2008 10:11:55 AM FLASH CID:52 COLOR:RED
8/8/2008 10:11:56 AM
8/8/2008 10:11:56 AM Model:V630i
8/8/2008 10:11:56 AM Brand:F SFR
8/8/2008 10:11:56 AM MAPP CXC article: R1JE001 prgCXC1250556_VODAFONE_MW
8/8/2008 10:11:56 AM MAPP CXC version: R1JE001
8/8/2008 10:11:56 AM Language Package:VFE_LIVE_2
8/8/2008 10:11:56 AM CDA article: CDA102514/24
8/8/2008 10:11:56 AM CDA version: R7A
8/8/2008 10:11:56 AM Default article: cxc1250557
8/8/2008 10:11:56 AM Default version: R1JE001
8/8/2008 10:11:56 AM PROVIDER: 000-00
8/8/2008 10:11:56 AM SIMLOCKS NOT DETECTED
8/8/2008 10:11:56 AM SEARCH:F:\SETool\v.0914037\eroms\DB2020EROM_CNV_RE D52_BROWN_CID49_DB2020.ssw
8/8/2008 10:11:58 AM RESTORATION FILE NOT PRESENT
8/8/2008 10:11:58 AM "R1JE001_CXC1250556_VODAFONE_MW"
8/8/2008 10:11:58 AM YOU MUST PERFORM FULL FLASHING
8/8/2008 10:11:58 AM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
8/8/2008 10:11:58 AM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
8/8/2008 10:11:58 AM Elapsed: 6 secs.
br
keaelite
The Following 2 Users Say Thank You to keaelite For This Useful Post:
Old 08-08-2008, 03:27   #2 (permalink)
Member: 31027
Thanks Meter: 179
how you conect TP
any easy TP
Old 08-08-2008, 03:28   #3 (permalink)
Registered User
GIGATT's Avatar
Member: 186342
Thanks Meter: 83
great job thanks
GIGATT
The Following User Says Thank You to GIGATT For This Useful Post:
Old 08-08-2008, 03:35   #4 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
Originally Posted by elsokary View Post
how you conect TP
any easy TP
no easy tp
i used tp for yobe chip
stage 1
pin 2
stage 2
pin 11
br
keaelite
Old 08-08-2008, 04:29   #5 (permalink)
IVERSON12312's Avatar
Member: 611338
Thanks Meter: 43
nice refference bro,congrats...........
The Following User Says Thank You to IVERSON12312 For This Useful Post:
Old 08-08-2008, 05:53   #6 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Great work, keep up. Me too have repaired a W850i yesterday... Akaward job, really needs skill..
The Following User Says Thank You to zeel_zeel For This Useful Post:
Old 08-09-2008, 05:45   #7 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
bro i got more than 5 /6 fone lyk k800 w580 k610 red light blinking but i need easy tp for dat i cn clear stage 1 need for stage 2
thnx in ad yasermalik
dadyal azad kashmir
Old 08-09-2008, 06:02   #8 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
dadyal azad kashmir
search w580 and k800 easy tp here but we dont have k610 easy tp
br
keaelite
Old 08-09-2008, 11:45   #9 (permalink)
persianuser's Avatar
Member: 516318
Thanks Meter: 27
plz show us ur tp in pic thanks
Old 10-08-2008, 03:49   #10 (permalink)
Member: 671345
Thanks Meter: 7
can u share us tp for k610?
Old 10-08-2008, 04:14   #11 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
what chip do you have?
br
keaelite
Old 10-08-2008, 06:45   #12 (permalink)
rudidar's Avatar
Member: 354893
Sonork: 100.1579833
Thanks Meter: 21
this is great to share with us .thanks bro...........
Old 10-08-2008, 07:26   #13 (permalink)
Member: 671345
Thanks Meter: 7
5060MOYOBE sir..thnx in advnce..
Old 10-08-2008, 07:30   #14 (permalink)
gujjar_brothers's Avatar
Member: 558087
Sonork: 100.1579413
Thanks Meter: 332
Thans for nice info Hard working
Old 10-08-2008, 07:35   #15 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
stage 1
pin1 & pin2
stage 2
pin 11 & pin 12
br
keaelite
The Following User Says Thank You to keaelite For This Useful Post:
>>> My X6-2 Successfully Repaired By SMTI <<< zeel_zeel SMTi 5 04-08-2009 22:35
>>> 6500s DAMAGED SP area REPAIRED by JAF BB5+ <<< keaelite JAF No Tp Unlocker by Cinek 5 03-22-2009 09:59
>>> K550i gdfs damaged successfully repaired <<< keaelite SETool2 3 11-17-2008 23:05
Go to first new post >>> K550i gdfs damaged successfully repaired <<< ayhen42 SETool2 1 08-06-2008 10:06
>>> another K800i gdfs damaged successfully repaired <<< keaelite SETool2 2 07-18-2008 10:18
Page generated in 0.32746 seconds with 9 queries
