08-17-2008, 09:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Unknown
Member: 603971 Status: Offline Thanks Meter: 730 | k800i dead after flash |
08-17-2008, 09:58 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | First identify Phone if its show Model:K700 or another Model than GDFS File Corrupted Repair it Via TP Method best Regards ALi |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
08-17-2008, 10:02 | #5 (permalink) |
Member: 603971 Status: Offline Thanks Meter: 730 | ALi06 check identify logo v0.914039/UNI 8/16/2008 11:38:48 PM CARD SERIAL: 00036521 8/16/2008 11:38:48 PM Loaded 51 flash descriptors 8/16/2008 11:38:49 PM SIGNED MODE (USING SERVER). 8/16/2008 11:38:49 PM Open COM port OK 8/16/2008 11:38:50 PM ChipID:9900,EMP protocol:0301 8/16/2008 11:38:50 PM Speed:921600 8/16/2008 11:38:50 PM Flash ID check:897E 8/16/2008 11:38:50 PM Flash props sent ok 8/16/2008 11:38:50 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701666662 CERT:N/A 8/16/2008 11:38:51 PM FLASH CID:53 COLOR:RED 8/16/2008 11:38:52 PM IMEI MISMATCH ! GDFS IMEI:35342701039440 8/16/2008 11:38:52 PM 8/16/2008 11:38:52 PM Model:K800i 8/16/2008 11:38:52 PM Brand:Generic Trade 8/16/2008 11:38:52 PM MAPP CXC article: R1KG001 prgCXC1250210_GENERIC_WI 8/16/2008 11:38:52 PM MAPP CXC version: R1KG001 8/16/2008 11:38:52 PM Language Package:EUROPE_1 8/16/2008 11:38:52 PM CDA article: CDA102239/43 8/16/2008 11:38:52 PM CDA version: R15A 8/16/2008 11:38:52 PM Default article: cxc1250490 8/16/2008 11:38:52 PM Default version: R1KG001 8/16/2008 11:38:52 PM PROVIDER: 000-00 8/16/2008 11:38:52 PM SIMLOCKS NOT DETECTED 8/16/2008 11:38:52 PM 8/16/2008 11:38:52 PM RESTORATION FILE NOT PRESENT 8/16/2008 11:38:52 PM "R1KG001_CXC1250210_GENERIC_WI" 8/16/2008 11:38:52 PM YOU MUST PERFORM FULL FLASHING 8/16/2008 11:38:52 PM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 8/16/2008 11:38:52 PM 8/16/2008 11:38:52 PM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE |
08-17-2008, 10:04 | #7 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Quote:
use test point method in setool for repair problem | |
08-17-2008, 10:13 | #9 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 818352 Status: Offline Thanks Meter: 266 | Quote:
This can be only solved by testpoint procedure. Firmwareupgrade or changing cid will not solve ur problem. If u have ur orginal gdfs backup it will also solve ur problem. Always ask Cocerned product supporter ur problem. User misguide many times as thy have habit of giving free advices which may harm ur phone. Br Unlock Trigger | |
08-17-2008, 10:16 | #11 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @ahmadge before Flashing U idenfity Phone if identify than Write First Identify Backup Otherwise use TP Method best reagrds ALi |
K800i Dead After 10 Minutes Of Flashing.... | multicom_fsdpk | SETool2 | 3 | 03-06-2008 15:23 |
K800i dead after unlocking via UB | Fones_Clinic_Network | Universalbox | 6 | 04-24-2007 14:54 |
K800i dead after multiserver | brick-it | Sony Ericsson | 3 | 02-09-2007 22:17 |
SE K800i DEAD AFTER FALLING | fusion007 | Sony Ericsson Hardware Repair | 0 | 12-21-2006 23:35 |
