07-09-2007, 07:47 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: in
Member: 524817 Status: Offline Thanks Meter: 206 | k800i unlock problem v0.91380091/UNI Card serial:00030157 Loaded 51 flash descriptors SERVER CREDITS LEFT/USED: 2/28 CARD COUNTERS: FLASH 14, UNLOCK 3 Elapsed:13 secs. SERVER SUPPORT ENABLED. SERVER CREDITS LEFT/USED: 2/28 CARD COUNTERS: FLASH 14, UNLOCK 3 Elapsed:11 secs. Open COM port OK unknown ChipID (6E04), RETRY phone pre-boot failed,possible RECOVERY needed. Elapsed:3 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170801475817 CERT:RED FLASH CID:49 COLOR:RED phone CID not supported in that mode Elapsed:2 secs. SERVER SUPPORT ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170801475817 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok bypassing DB2020 security... server step1 error:10054 unlock failed, that is fatal Elapsed:24 secs. this error help me plzzzzzzzz |
07-09-2007, 08:08 | #3 (permalink) |
No Life Poster Join Date: Dec 2004
Member: 97600 Status: Offline Thanks Meter: 97 | this is what it should look like v0.91380091/UNI Card serial:0000**** Loaded 51 flash descriptors SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:351707014***** CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok bypassing DB2020 security... done,restarting... ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: DB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R1CB001_CXC1250210_GENERIC_WI Restore from:R1CB001_CXC1250210_GENERIC_WI full sig complete. USERCODE reset to "0000" Searching... Firmware lock check determined. Unlock Done Elapsed:72 secs. SERVER SUPPORT ENABLED. SERVER CREDITS LEFT/USED: 37/23 CARD COUNTERS: FLASH 42, UNLOCK 21 Elapsed:2 secs. |
07-09-2007, 08:14 | #4 (permalink) | |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | Quote:
change ip and try again all well be okey also do not share ur account to anyone REGARDS GSM MIND | |
K800i unlock problem with CR 13.00 | hdx01 | Sony Ericsson | 0 | 11-21-2007 18:32 |
K800i UNLOCK PROBLEM | Nasmi | Universalbox | 8 | 10-10-2007 14:45 |
Sony ericsson K800i Unlock Problem Help... | Lorelas | Sony Ericsson | 1 | 08-25-2007 22:54 |
k800i unlock problem | anildeepak | Universalbox | 1 | 05-07-2007 07:34 |
K800i Unlock Problem | drgmobile | Universalbox | 30 | 01-14-2007 23:02 |
