03-17-2012, 02:39 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 772007 Status: Offline Thanks Meter: 1 | LG LU6800(Korea) Reset Factory by LGTool Help ??? I need help about for LU6800 hardreset or factory reset or Files Frimware . Pls Thank On Phone press " Emergency Call " , Press " 3845#*6800# not work and LGTool not connect mobile . |
03-21-2012, 09:56 | #4 (permalink) |
No Life Poster Join Date: Jul 2010 Location: mindanao L-D-S
Member: 1339214 Status: Offline Thanks Meter: 514 | Procedure, type "3845#*6800#" in the number dialing window enter into the service menu select "AP CP USB Switching" menu and select "CP USB" option there. then connect usb cable to phone to pc open lgetool, select model. |
The Following 2 Users Say Thank You to amar85 For This Useful Post: |
03-24-2014, 16:08 | #10 (permalink) |
Freak Poster Join Date: Sep 2011 Location: mongolia
Member: 1662556 Status: Offline Sonork: 100.1635040 Thanks Meter: 45 | pls turn off phone, press and hold volume up + insert usb(emergence) open lgtool , choose model to lu6800 press factory reset button waiting |
The Following User Says Thank You to CDMA_MONGOLIA For This Useful Post: |
04-23-2014, 10:35 | #11 (permalink) |
Freak Poster Join Date: Nov 2008 Location: VietNam Team Age: 49
Member: 890799 Status: Offline Sonork: 100.999999 Thanks Meter: 384 | GOOD JOBS THANK To connect the phone you should remove accumulator and then connect the cable to the handset If you need to enter into the LG service menu type "3845#*6800#" in the number dialing window To enter the provider hidden menu you need type service password which is shown in the log then type service password once more Usually the service password is 147789 Connecting with LU6800 Firmware Version: LU680128 Bluetooth Address: 70:05:14:09:80:83 Connected Receiving phone info Firmware Released: 19:00:00 Firmware Compiled: 00:33:02 Connect mode: Normal Meid unlock code 0223fc21033db0ce Firmware Version: LU680128 SPC: 000000 MEID: A000003124502F Mobile ESN: 80235039 Bluetooth Address: 70:05:14:09:80:83 Phone Number(MDN): 01068121219 min1: 8121219 min2: 106 SSD_A: 40A90C74472758CA SSD_B: 1E18A8845ED0C450 AKEY: 00000000000044967056 User Lock Code: 0000 MCC: 450 MNC: 6 Info received Restoring to factory defaults Cant switch the mobile phone to download mode You can make it manually OMAP User Data Clear Done AP part has been successfully reseted If you want to continue work with the handset you should reconnect it with special buttons pressed as you did it when you connected the first time Don't forget to restart the phone Factory defaults successfully restored |
01-10-2016, 07:34 | #13 (permalink) |
Freak Poster Join Date: Feb 2012 Location: shakil mobile pakistan
Member: 1726210 Status: Offline Thanks Meter: 25 | own in the log then type service password once more Usually the service password is 147789 Connecting with LU6800 Firmware Version: LU680128 Bluetooth Address: A8:92:2C:4F:07:F6 Connected Receiving phone info Firmware Released: 19:00:00 Firmware Compiled: 00:33:02 Connect mode: Normal Meid unlock code 00f9bae701a0b80f Firmware Version: LU680128 SPC: 000000 MEID: A1000019A156E7 Mobile ESN: 80425AD2 Bluetooth Address: A8:92:2C:4F:07:F6 Phone Number(MDN): 01000000000 min1: 0000000 min2: 100 SSD_A: 0000000000000000 SSD_B: 0000000000000000 AKEY: 00000000000044967056 User Lock Code: 0000 MCC: 450 MNC: 6 Info received Restoring to factory defaults Cant switch the mobile phone to download mode You can make it manually OMAP User Data Clear Done AP part has been successfully reseted If you want to continue work with the handset you should reconnect it with special buttons pressed as you did it when you connected the first time Don't forget to restart the phone Factory defaults successfully restored |
11-08-2016, 12:49 | #15 (permalink) |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Great Connecting with LU6800 Firmware Version: LU680159 Bluetooth Address: A8:92:2C:44:B5:2C Connected Receiving phone info Firmware Released: 19:00:00 Firmware Compiled: 07:53:10 Connect mode: Normal Meid unlock code 00c8d65c02dc8a0c Firmware Version: LU680159 SPC: 000000 MEID: A1000019809EC2 Mobile ESN: 80B8EFA1 Bluetooth Address: A8:92:2C:44:B5:2C Phone Number(MDN): 01000000000 min1: 0000000 min2: 100 SSD_A: 0000000000000000 SSD_B: 0000000000000000 AKEY: 00000000000044967056 User Lock Code: 0000 MCC: 450 MNC: 6 Info received Restoring to factory defaults Cant switch the mobile phone to download mode You can make it manually OMAP User Data Clear Done AP part has been successfully reseted If you want to continue work with the handset you should reconnect it with special buttons pressed as you did it when you connected the first time Don't forget to restart the phone Factory defaults successfully restored |
