11-29-2011, 11:26 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Nord Romania Age: 42
Member: 323481 Status: Offline Thanks Meter: 43 | LT18i unlock done by setool using testpoint REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 64 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 35850604242826 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1256] WRITING SEMCBOOT ... Unlock DONE Procedure: 1. prepare for testpoint operation. check testpoints location for your phone model in dist\docs\s1_qualcomm_uart_cables or use GPG cable set open testpoints for access if you do not have GPG cable set, get some needle with wire, connect it to phone gnd ( battery minus ) or to usb cable shield, etc. 2. select proper phone model. select COM as interface. on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset, use testpoint (gnd type) fill login/password and check if account valid. press unlock when prompted, execute steps in EXACT order:
The Following 3 Users Say Thank You to kosta25 For This Useful Post: |
11-29-2011, 13:19 | #2 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: NICE MOBILES Age: 35
Member: 1293519 Status: Offline Sonork: 100.1596500 Thanks Meter: 169 | Quote:
07-28-2012, 15:19 | #4 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lagos, Nigeria
Member: 152547 Status: Offline Sonork: 100.1586021 Thanks Meter: 143 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... llbug: write error: "The device does not recognize the command" llbug: blk write fail.fatal qcSendPacket: can't send packet. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 64 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 180 secs. |
10-06-2012, 10:40 | #8 (permalink) |
No Life Poster Join Date: May 2010 Location: South America Age: 41
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | can you show us the picture with the test point please, and i hear that this model LT18i canīt be unlocked, models made in 2012 can not be unlock. thx for some aclarations pls |
11-11-2012, 11:21 | #9 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Kerala
Member: 37015 Status: Offline Thanks Meter: 67 | CARD COUNTERS: FLASH 174, UNLOCK 54 Elapsed: 2 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 107 secs. how can solve this error? |
11-11-2012, 12:25 | #10 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,440 | new security (99.99%) if erom >=r9xxxx and YearwWeek >=12w14 read post #12 HOW TO WORK WITH SEMC PDA PHONES - Page 2 |
06-24-2013, 15:19 | #11 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: lusaka
Member: 320108 Status: Offline Thanks Meter: 18 | Quote:
05-28-2016, 19:55 | #12 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | 28/05/2016 17:20:21 RUNNING v 1.1404/01.15/UNI 28/05/2016 17:20:21 CARD SERIAL 00236xxx 28/05/2016 17:20:21 USBFLASH DRIVER VERSION 03.00.00.00 28/05/2016 17:26:12 SIGNED MODE (USING SERVER) 28/05/2016 17:26:12 ALTERNATIVE SECURITY BYPASS ENABLED 28/05/2016 17:26:12 CFG:110010000000 28/05/2016 17:26:12 28/05/2016 17:26:12 DETACH USB CABLE FROM PHONE 28/05/2016 17:26:12 REMOVE BATTERY FROM PHONE 28/05/2016 17:26:12 ATTACH TESTPOINT 28/05/2016 17:26:12 PRESS "READY", THEN ATTACH USB CABLE TO PHONE 28/05/2016 17:26:12 28/05/2016 17:28:03 PROCESSING ... 28/05/2016 17:28:04 REMOVE TESTPOINT NOW, THEN PRESS "READY" 28/05/2016 17:28:04 28/05/2016 17:28:12 PLEASE ATTACH TURNED OFF PHONE NOW 28/05/2016 17:28:12 PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... 28/05/2016 17:28:14 28/05/2016 17:28:14 RUNNING S1_LOADER VER "R4A069" 28/05/2016 17:28:14 28/05/2016 17:28:14 EROM_AID : 0001 28/05/2016 17:28:14 LOADER_AID : 0001 28/05/2016 17:28:14 HWCONF_AID : 0001 28/05/2016 17:28:14 ACTIVE_LOADER_AID : 0001 28/05/2016 17:28:14 28/05/2016 17:28:18 DEVICE ID: 18A5E74DCEEED365ED81393AC49DBCD1B171D1F7 28/05/2016 17:28:18 FLASH ID: "002C/00B3" 28/05/2016 17:28:18 LOADER VERSION: "r4A069" 28/05/2016 17:28:18 28/05/2016 17:28:18 PHONE IMEI : 35850604218325 28/05/2016 17:28:20 Checking for signature ... 28/05/2016 17:28:21 WRITING SEMCBOOT ... 28/05/2016 17:28:22 Unlock DONE 28/05/2016 17:28:22 Elapsed: 130 secs. |
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post: |
04-27-2017, 09:27 | #15 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 47
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... 0806010100900000 0D1450424C5F446F776E6C6F6164657256455231 030006 030006 030006 PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start IF TESTPOINT DONE OK,THIS IS NOT SUPPORTED MCU REVISION FAILED TO SETUP PHONE Unlock FAILED Elapsed: 30 seconds Not done |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
