08-14-2017, 11:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2017
Member: 2711286 Status: Offline Thanks Meter: 27 | please help to unlock w595..(solved) RUNNING v 1.1426/01.15/UNI CARD SERIAL 00163316 USBFLASH DRIVER VERSION 03.01.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 362 seconds CFG:000000000000 ChipID: C900, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0052 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35842403021382 CERT:RED LDR: 2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Unlock DONE Elapsed: 47 seconds but not unlocked!!!!!!!! |
08-14-2017, 15:25 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | you don't need any further driver to unlock your phone just tick use server + alternative bypass i.e 1+2 press unlock Press and hold 2+5 and connect the phone the phone will be unlocked InshAllah |
The Following User Says Thank You to :Aishur: For This Useful Post: |
08-14-2017, 16:02 | #6 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | reinstall setool\driver\usbflash_driver\ggsetup-3.1.0.11.exe manual update the driver and redirect to the location C:\Program Files (x86)\Sony Mobile\Gordons Gate anyway no further drivers are needed https://www.sendspace.com/file/brmv79 |
08-14-2017, 16:57 | #7 (permalink) | |
Member: 2711286 Status: Offline Thanks Meter: 27 | Quote:
Elapsed: 189 seconds SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID: C900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35842403021382] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35842403021382 CERT:RED LDR: 2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 GOT SEED: 6DAE71CC3480187835603805 P96 AUTH PASSED RESTARTING ... ChipID: C900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35842403021382] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35842403021382 CERT:RED DEVICE KEY: 99D654A1EB9D74A3BD2729875D03E2D0 (1) LDR: 2009-06-26 15:54 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:54 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A082 GOT SEED: D187ADFE3480187835603805 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE ... RESTARTING ... ChipID: C900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35842403021382] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35842403021382 CERT:BROWN LDR: 2010-03-02 17:56 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 96 LDR: 2010-03-02 17:56 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 96 WRITING SEMCBOOT ... PREPARING SECURITY ... PHONE DOMAIN: "RED" WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "11441300" SIGNING ... DEVICE KEY RESTORED Unlock DONE Elapsed: 37 seconds but not unloked | |
08-14-2017, 17:39 | #9 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | Regarding to setool, your phone is unlocked now what is it the phone message on the screen check the lock status by dialing *<<* (star, left, left, star) or press identify this time press and hold "C" button instead of 2+5 ones check also another sim |
08-14-2017, 17:43 | #10 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | ha ha ha it is an another issue without loading firmware tick ONLY, signed mode + complete phone after flash (1+3) press flash That is all |
The Following 2 Users Say Thank You to :Aishur: For This Useful Post: |
08-14-2017, 18:05 | #13 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | You are welcome, Bro Next time for accurate and reliable help, please visit setool forum https://support.setool.net/forum.php Greetings go to the_laser |
