02-21-2010, 19:48 | #1 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16927 Status: Offline Thanks Meter: 134 | SE K300 unlock problem...:) today get strange K300, when try to unlock him i get message: Code: RUNNING v0.915060/UNI CARD SERIAL xxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000100000000 ChipID:8000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0036 Speed:921600 OTP: LOCKED:1 CID:36 PAF:1 IMEI:35998600xxxxxx CERT:RED LDR:040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E can't get packet start. Elapsed: 35 secs. I try to repair GDFS, press Recovery and all was ok: Code: CFG:000100000000 RECOVERY MODE STARTED ChipID:8000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0036 Speed:921600 REC:041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Fetching phone data from OTP OTP: LOCKED:1 CID:36 PAF:1 IMEI:35998600xxxxxx CERT:RED Recovery succefull. Reflash phone now Elapsed: 6 secs. ps. i also try unlock by USB-SMART , simillar problem any idea with grandfather phone? br, fingusio |
02-21-2010, 20:56 | #4 (permalink) |
Member: 16927 Status: Offline Thanks Meter: 134 | also dont work Code: RUNNING v0.915060/UNI CARD SERIAL xxxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000010 ATTACH TESTPOINT NOW, THEN PRESS "READY" ChipID:8000,EMP protocol:0301 PHONE STATE: "UNKNOWN" [00000000] SUPPORTED FLASH CID IS NOT DETECTED [0259] Speed:921600 RELEASE TESTPOINT NOW, THEN PRESS "READY" OTP: LOCKED:1 CID:36 PAF:1 IMEI:35998600xxxxxx CERT:N/A can't get packet start. Loader not responding ! Elapsed: 43 secs. br, fingusio |
02-21-2010, 22:22 | #5 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | if it can't be unlocked - most probably gdfs is damaged and you must rewrite gdfs with re-formatting (go to settings tab, check "format gdfs"). all needed gdfs is inside "gdfs_in_bin_format,gdfs_in_ssw_format" folders of setool2 distr. select corresponding gdfs in "misc files" edit and press "write gdfs" always make "unlock" after write gdfs. please note, that you SHOULD NOT mess with gdfs in db2020 phones, pnx5230 phones, cid50/51/52 db2010 phones. actually, you only can safely rewrite gdfs on db2000/db2010 cid16/29/36/49 phones. |
The Following User Says Thank You to roney_nexus For This Useful Post: |
02-22-2010, 10:21 | #7 (permalink) |
Member: 16927 Status: Offline Thanks Meter: 134 | @roney_nexus Same thing... hang on Sending Loader....and get this error like below. Code: RUNNING v0.915060/UNI CARD SERIAL xxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000100 Will write GDFS now. ChipID:8000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0036 Speed:921600 OTP: LOCKED:1 CID:36 PAF:1 IMEI:35998600xxxxxx CERT:RED LDR:040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E can't get packet start. Elapsed: 47 secs. br, fingusio |
01-06-2011, 15:19 | #8 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Romania
Member: 730652 Status: Offline Thanks Meter: 74 | With setool v1.10 I cleaned the plug very good, with cable RJ45 RUNNING v 1.10/ PHONE STATE: "RETAIL" FLASH CID: 0036 Speed:115200 LDR:050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F OTP LOCKED:1 CID:36 PAF:1 IMEI:35790900961322 CERT:RED LDR:040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Restarting... ChipID:8000,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0036 Speed:115200 LDR:050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F OTP LOCKED:1 CID:36 PAF:1 IMEI:35790900961322 CERT:BROWN LDR:040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 200D Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "74586874" SIGNING... Unlock DONE Elapsed: 43 secs. Ok ! |
SE Remote Unlocker Problem | sam-man | Sony Ericsson | 7 | 04-10-2005 10:51 |
Se t230 unlocking problem | Mirken | UFS2 + UFS3-Tornadoflasher | 2 | 03-18-2005 21:59 |
se v802 unlock problem | Siemens man | Griffin | 1 | 03-13-2005 13:44 |
se v800 unlock problem | Siemens man | Griffin | 9 | 01-29-2005 23:53 |
Sony J70 strange Unlock problem :) | bluelights | Sony | 7 | 03-12-2002 22:42 |
