03-29-2010, 07:06 | #1 (permalink) |
Freak Poster Join Date: Jun 2005
Member: 154932 Status: Offline Thanks Meter: 6 | SE K770i Whats the problem, Pls check logs [CORUNNING v1.0/UNI CARD SERIAL 00033068 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35223902229087 CERT:N/A FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35852401899806 Model (from GDFS):K770i Brand:Generic MAPP CXC article: R8BA024 prg1201-7587_GENERIC_VI MAPP CXC version: R8BA024 Language Package: APAC CDA article: 1202-3377 CDA version: R2A Default article: 1201-7603 Default version: R8BA024 PROVIDER: 234-15 Network LOCKED RESTORATION FILE NOT PRESENT "R8BA024_1201-7587_GENERIC_VI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 8 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35223902229087 CERT:RED FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35852401899806 Model (from GDFS):K770i Brand:Generic MAPP CXC article: R8BA024 prg1201-7587_GENERIC_VI MAPP CXC version: R8BA024 Language Package: APAC CDA article: 1202-3377 CDA version: R2A Default article: 1201-7603 Default version: R8BA024 PROVIDER: 234-15 Network LOCKED SEARCH:\SETool 3\FLASH_FILES\DB2020\K770i\CID 52\MAIN\R8BA024\R8BA024_7587_GENERIC_VI.ssw "R8BA024_1201-7587_GENERIC_VI" CREATED SECURITY UNITS BACKUP CREATED. Elapsed: 22 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35223902229087 CERT:RED FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35852401899806 Model (from GDFS):K770i Brand:Generic MAPP CXC article: R8BA024 prg1201-7587_GENERIC_VI MAPP CXC version: R8BA024 Language Package: APAC CDA article: 1202-3377 CDA version: R2A Default article: 1201-7603 Default version: R8BA024 PROVIDER: 234-15 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 8 secs. DE][/CODE] |
03-29-2010, 08:12 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. imei reapir too whil;e flash |
ZT555 help master cannot on...pls check logs... | dhie2424 | Chinese Models & Cloned Phones | 2 | 11-10-2009 14:06 |
unlocking Vodafone 533 whats the problem ? pls chek | Gago_ | FuriousGold | 5 | 10-24-2009 15:11 |
plz anyone check this what the problem ? | Faheem Anjum | Off Topic Zone | 0 | 10-08-2009 13:26 |
whats the problem Check This | asia_gsm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-25-2009 13:31 |
