10-18-2010, 11:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: pakistan
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | setool supporter only CFG:000000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35821803932701] OTP LOCKED:1 CID:53 PAF:1 IMEI:35821803932701 CERT:RED LDR:2010-01-28 19:45 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A093 LDR:2010-01-28 19:46 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A093 Model (from GDFS):W995 MAPP CXC article: R1GA026 prg1215-8017_ORANGE_HI MAPP CXC version: R1GA026 Language Package: ORANGE-SIGN CDA article: 1227-4836 CDA version: R7A Default article: 1215-7993 Default version: R1GA026 PROVIDER: 234-33 Network LOCKED Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100001000000 SERVER CREDITS LEFT/USED: 29/1 CARD COUNTERS: FLASH 363, UNLOCK 252 Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35821803932701] OTP LOCKED:1 CID:53 PAF:1 IMEI:35821803932701 CERT:RED LDR:2010-01-28 19:45 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:46 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] Elapsed: 35 secs. SIGNED MODE (USING SERVER) CFG:100001000000 SERVER CREDITS LEFT/USED: 28/2 CARD COUNTERS: FLASH 363, UNLOCK 252 Elapsed: 3 secs. tell me what is this and give back my credit,,, |
The Following User Says Thank You to zeeshan tayyab For This Useful Post: |
10-18-2010, 11:37 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | OTP LOCKED:1 CID:53 PAF:1 IMEI:35821803932701 CERT:RED Need 1 crd for CID 53 A2 phone if you not Active ur Setool |
The Following User Says Thank You to srkhan For This Useful Post: |
10-18-2010, 12:06 | #4 (permalink) |
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | i think u did not provide us full Log, where we can see the unlock Code. ALL UNLOCK/LOCK CODES SET TO "xxxxxxxx" then manually put unlock code by >*<<*<* |
10-18-2010, 12:21 | #5 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED Then Press n Hold 2+5 insert USB cable unlock without credits,,, UNLOCKED_LOGS_WITHOUT_CREDITS: -------------------------------------- 3/30/2010 1:24:45 PM RUNNING v 1.01/UNI 3/30/2010 1:24:45 PM CARD SERIAL 0000000 3/30/2010 1:24:45 PM PLEASE UPGRADE USBFLASH DRIVER 01.01.00.0C 3/30/2010 1:31:43 PM SIGNED MODE (USING SERVER) 3/30/2010 1:31:43 PM ALTERNATIVE SECURITY BYPASS ENABLED 3/30/2010 1:31:43 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 3/30/2010 1:31:43 PM CFG:110000000000 3/30/2010 1:32:14 PM PROCEDURE WAS STOPPED BY USER 3/30/2010 1:32:14 PM FAILED TO SETUP PHONE 3/30/2010 1:32:14 PM Elapsed: 31 secs. 3/30/2010 1:37:04 PM SIGNED MODE (USING SERVER) 3/30/2010 1:37:04 PM ALTERNATIVE SECURITY BYPASS ENABLED 3/30/2010 1:37:04 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 3/30/2010 1:37:04 PM CFG:110000000000 3/30/2010 1:37:04 PM ChipID:E900,EMP protocol:0401 3/30/2010 1:37:04 PM BOOTROM MODE DETECTED 3/30/2010 1:37:04 PM OTP DBG: [1,53,1,35821803210563] 3/30/2010 1:37:07 PM OTP LOCKED:1 CID:53 PAF:1 IMEI:35821803210563 CERT:RED 3/30/2010 1:37:09 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082 3/30/2010 1:37:11 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082 3/30/2010 1:37:16 PM GOT SEED:B659E40E35804A7735306833 3/30/2010 1:37:17 PM P96 AUTH PASSED 3/30/2010 1:37:17 PM RESTARTING... 3/30/2010 1:37:20 PM ChipID:E900,EMP protocol:0401 3/30/2010 1:37:20 PM BOOTROM MODE DETECTED 3/30/2010 1:37:20 PM OTP DBG: [1,53,1,35821803210563] 3/30/2010 1:37:23 PM OTP LOCKED:1 CID:53 PAF:1 IMEI:35821803210563 CERT:RED 3/30/2010 1:37:23 PM DEVICE KEY:6560B760A3755CB3874C480C442C7FD7 (0) 3/30/2010 1:37:24 PM LDR:2009-04-21 18:39 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A081 3/30/2010 1:37:24 PM LDR:2009-04-21 18:40 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A081 3/30/2010 1:37:26 PM GOT SEED:EF1B683E35804A7735306833 3/30/2010 1:37:27 PM P96 AUTH PASSED 3/30/2010 1:37:27 PM RESETTING SECURITY TO FACTORY STATE... 3/30/2010 1:37:27 PM RESTARTING... 3/30/2010 1:37:30 PM ChipID:E900,EMP protocol:0401 3/30/2010 1:37:30 PM BOOTROM MODE DETECTED 3/30/2010 1:37:30 PM OTP DBG: [1,53,1,35821803210563] 3/30/2010 1:37:33 PM OTP LOCKED:1 CID:53 PAF:1 IMEI:35821803210563 CERT:BROWN 3/30/2010 1:37:33 PM LDR:2009-06-26 16:10 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A082 3/30/2010 1:37:35 PM LDR:2009-06-26 16:11 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A082 3/30/2010 1:37:35 PM WRITING SEMCBOOT... 3/30/2010 1:37:36 PM PREPARING SECURITY... 3/30/2010 1:37:36 PM WRITING CLEAR SIMLOCK UNITS... 3/30/2010 1:37:36 PM ALL UNLOCK/LOCK CODES SET TO "72684331" 3/30/2010 1:37:38 PM CHANGING DOMAIN TO "CURRENT" 3/30/2010 1:37:38 PM SIGNING... 3/30/2010 1:37:39 PM DEVICE KEY RESTORED 3/30/2010 1:37:39 PM Unlock FINISHED 3/30/2010 1:37:39 PM Elapsed: 34 secs. BR |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
