08-17-2017, 19:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: egypt Age: 37
Member: 419703 Status: Offline Thanks Meter: 123 | setool2 box does not work on modern releases The box does not work on modern releases The box works on an old version v1.04 Attached is your image error v1.1423 Attachment your image to the ActiveX Box plz help me Does the box needs updating? Does the box need activation again? Do the box need yoser and bass? What is the problem and the solution? |
08-21-2017, 16:30 | #2 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | plz help me Does the box needs updating? Does the box need activation again? Do the box need yoser and bass? What is the problem and the solution? |
08-21-2017, 21:20 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | You must activate your smart card in order to use v1.1106+ versions.. Its a paid update |
The Following User Says Thank You to voltran2008 For This Useful Post: |
08-22-2017, 12:36 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | it is easy to check it download card updater http://setool.net/support/SETool2/updater.zip put the updater.exe in setool folder run the updater.exe log for an updated card Code: setool2 SmartCard updater [0.95] server read: "srv01.dontexist.com" username read: "updater" Please click on reader with setool2 SmartCard. Ready to work SmartCard update started... CARD SERIAL: 00000001 Checking with server..... auth #0 err: [update not required] |
The Following User Says Thank You to :Aishur: For This Useful Post: |
08-24-2017, 00:45 | #5 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | setool2 SmartCard updater [0.95] server read: "srv01.dontexist.com" username read: "updater" Please click on reader with setool2 SmartCard. Please click on reader with setool2 SmartCard. Ready to work SmartCard update started..... CARD SERIAL: 00059637 Checking with server... setool2 card not activated, credits will be used.. auth #0 err: [No credits left] |
