01-09-2009, 08:43 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: INDONESIA
Member: 527741 Status: Offline Thanks Meter: 355 | SOLUTION SONYERICSON W830 BLANK/RESTART/ setGDFS_params failed TESTED BY ME 100 % GOODS v0.915030/UNI CARD SERIAL: UCOKMONALISA Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 36 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER setGDFS_params failed failed to setup GDFS Elapsed: 16 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 61 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER setGDFS_params failed failed to setup GDFS Elapsed: 16 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 10 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok Elapsed: 13 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED Model:W830i MAPP CXC article: R1KG001 prgCXC1250710_CHINA_EA MAPP CXC version: R1KG001 Language Package:APAC CDA article: CDA102721/4 CDA version: R3A Default article: cxc1250714 Default version: R1KG001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35457901355430 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed USERCODE RESET TO "0000" Elapsed: 27 secs. SOLUTION -CONNECT TO INTERNET -CONNECT CABLE FLASH -TIK SIGNED MODE (USE SERVER FOR BYPAS/CSCA) - DON’T USE FLASH FILE/IF YOU USE FLASH FILE ABOUT TO ALTERNATED MODE BE K700 -TIK FLASH WAIT FINISH EX…………. v0.914037/UNI CARD SERIAL: ucokmonalisa Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35457901406012 CERT:N/A FLASH CID:52 COLOR:RED Model:W830i MAPP CXC article: R1KG001 prgCXC1250710_CHINA_EA MAPP CXC version: R1KG001 Language Package:APAC CDA article: CDA102721/4 CDA version: R3A Default article: cxc1250714 Default version: R1KG001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1KG001_CXC1250710_CHINA_EA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWAR Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35457901406012 CERT:N/A FLASH CID:52 COLOR:RED Model:K700 MAPP CXC article: R1KG001 prgCXC1250710_CHINA_EA MAPP CXC version: R1KG001 Language Package:APAC CDA article: CDA102721/4 CDA version: R3A Default article: cxc1250714 Default version: R1KG001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 5 secs. B.R UCOKMONALISA |
The Following User Says Thank You to ucokmonalisa For This Useful Post: |
01-13-2009, 11:52 | #5 (permalink) |
Member: 527741 Status: Offline Thanks Meter: 355 | @OnyGSM thanks for share... Are that's step need credit??? no need credit only tik SIGNED MODE (USE SERVER FOR BYPAS/CSCA) and tik flash............ If it can't help Try solution PAR Aishur http://www.centralmobile.net/vbb/sho...highlight=W830 From now, USE ONLY DCU-60 cable for cid >=49 any models hope that you used once the dcu-60 restore the earlier security unit backup enter in misc file $My setool instalation$\backup\35457901406012\35457901406012_date_time, then write script if it can't help Use old method (version 28) Flash Cid53 firmwares MAIN + FS (apac is present) settings, user server enable alternative security bypass complete phone after flash If it can't help Use tp method of course, here, com cable can be used Best regards |
01-13-2009, 18:48 | #6 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Java Age: 46
Member: 166000 Status: Offline Thanks Meter: 26 | Solution for what ????? Flash Cid53 firmwares MAIN + FS (apac is present) settings, user server enable alternative security bypass complete phone after flash If it can't help Use tp method ofcourse that part only i understand, not the other |
01-30-2009, 09:05 | #8 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Tested ...... Thanks for share ........... PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35494301130622 CERT:RED FLASH CID:49 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 74 secs. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35494301130622 CERT:RED FLASH CID:49 COLOR:RED Model:Z530i MAPP CXC article: R6DA001 prgCXC1250454_GENERIC_MU MAPP CXC version: R6DA001 Language Package:HONG_KONG CDA article: CDA102295/7 CDA version: R2A Default article: cxc1250290 Default version: R6DA002 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BR. thushdt |
01-31-2009, 08:12 | #9 (permalink) | |
Member: 527741 Status: Offline Thanks Meter: 355 | @thushdt Quote:
TESTED BY ME OPEN SOFTWARE SETOOL TIK EMPTY FILL&REPAIR MAKE MAIN.SWW... MAKE FS...... MAKE GSFS_IN_SSW_FORMAT DB2O10 Z530.GDFS....... WRITE...IMEI ORIGINAL TIK FLASH REMOVE BATTRY WAIT FINISH/DONE IF CONFINGURATION ERROR.... FLASH AGAIN... MAKE....MAIN MAKE FS... FLASH... REMOVE BATTRY/INSERT WAIT FINISH IF STILL REHOT POWER IC PLEASE.......TRY.... EX.... Open COM port OK ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35238201501036 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND VERSION "R4CH003_CXC1250232_CHINA_CO" can't open file "C:\SETOOL\yogya ponsel\Disc 2\rest\R4CH003_CXC1250232_CHINA_CO" writing "C:\SETOOL\yogya ponsel\Disc 2\gdfs_in_ssw_format\db2010\k510_gdfs_in_ssw_forma t.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:32 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... setGDFS_params failed failed to setup GDFS final preparation fail. see messages above. Elapsed: 135 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35238201501036 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND VERSION "R4CH003_CXC1250232_CHINA_CO" can't open file "C:\SETOOL\yogya ponsel\Disc 2\rest\R4CH003_CXC1250232_CHINA_CO" writing "C:\SETOOL\yogya ponsel\Firmware SE Tool\Firmware SE Tool\K510\R4CH003\r4ch003_china_main.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:337 Will flash 337 blocks... SSW loading returns:0 writing "C:\SETOOL\yogya ponsel\Firmware SE Tool\Firmware SE Tool\K510\R4CH003\r4ch003_apac_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:105 Will flash 105 blocks... SSW loading returns:0 writing "C:\SETOOL\yogya ponsel\Firmware SE Tool\gdfs_in_ssw_format\k510_gdfs_in_ssw_format_v0 .ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:32 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "43442478" SIGNING... Elapsed: 545 secs. B.R | |
w200 setGDFS_params failed help | speed infotech | SETool2 | 3 | 03-13-2010 14:09 |
setGDFS_params failed | jamal_sdp | SETool2 | 6 | 03-04-2010 13:52 |
K320i setGDFS_params failed How To Fix? | jr_buenaflor | SETool2 | 2 | 02-06-2010 17:55 |
w830 blank | nO3Rc4o7i5 | D-Unlock Suite | 0 | 07-17-2009 13:14 |
Help SonyEricson T100 is restarting and freezing | PetarPhone | Sony Ericsson Hardware Repair | 0 | 03-18-2005 20:33 |
