01-25-2010, 15:46 | #1 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1065550 Status: Offline Sonork: gsmstar Thanks Meter: 12 | K800 CID 49 Unlocking I have to unlock K800 with CID 49. I used to upgrade the CID by 52 in old versions by Script txt.file. But in newer version how can I unlock it the file is not available in Script. Plz tell me if there any other procedure. Thanks, |
02-08-2010, 10:10 | #3 (permalink) |
Crazy Poster Join Date: May 2004 Location: syria Age: 55
Member: 64371 Status: Offline Thanks Meter: 6 | this is know v0.915057/UNI CARD SERIAL: 00018071 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110110000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101962316 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 bypassing security... server step1 error:bad username/password. loader unlock failed, that is fatal Elapsed: 15 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111110000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101962316 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM166 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Starting embedded bootloader... can't get packet start. embedded flashloader not responds ! Elapsed: 181 secs. SIGNED MODE (USING SERVER) CFG:100111000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101962316 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 writing "D:\ggggg\v0.915057\w850\R1KG001_1250200_GENERIC_C Y.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 14 secs. |
02-10-2010, 13:56 | #7 (permalink) |
Member: 1065550 Status: Offline Sonork: gsmstar Thanks Meter: 12 | Which options has to be selected for K800 with CID 49 for unlocking and which file is required? and do I need to Flash or Unlock option. Thanks, |
The Following User Says Thank You to gsmstars For This Useful Post: |
02-22-2010, 18:47 | #9 (permalink) |
Freak Poster Join Date: May 2009
Member: 1034869 Status: Offline Thanks Meter: 9 | after recovery K800i I can boot only with "5" and "2-5" and fleshing isn't possible! SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401943524 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "D:\gsm2006\SETool3\k800\R8BF003_1250210_GENERIC_W I.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 34 secs. HELP! |
02-22-2010, 19:54 | #10 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Vancouver BC & Kathmandu Nepal
Member: 538410 Status: Offline Sonork: 100.1590750 Thanks Meter: 193 | Quote:
The Following User Says Thank You to robean For This Useful Post: |
02-22-2010, 20:09 | #11 (permalink) |
Member: 1034869 Status: Offline Thanks Meter: 9 | I repair EROM with Cruiser ultimate unlocker and now is C boot mode again active! But problem is the same! I try with 3 different flash types! R1JG001_1250210_GENERIC_WI.ssw R1JG001_FS_S_E_EUROPE_WI_RED_CID52.ssw R8BF003_1250210_GENERIC_WI_cid53.ssw R8BF003_FS_S_E_EUROPE_WI_RED_CID53.ssw R8BF003_1250210_GENERIC_WI.ssw R8BF003_FS_S_E_EUROPE_WI_RED_CID52.ssw but same problem! HDR block not accepted,error: 19 ----------------------------- log RUNNING v0.915060/UNI CARD SERIAL 0006**** USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100100000000 SERVER CREDITS LEFT/USED: 13/17 CARD COUNTERS: FLASH 19, UNLOCK 42 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3557040194**** CERT:BROWN FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "D:\gsm2008\SETool3\k800\R8BF003_1250210_GENERIC_W I.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 60 secs. |
02-22-2010, 21:26 | #12 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | heiiii man your phone cid 49 and you wont to flash it with cid 52 ...53 what you doing man your phone still cid49 so try to find flash cid49 and flash it thats alllllllllllllllllllllllllll.... |
02-22-2010, 21:34 | #13 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | HDR block not accepted,error: 19 that is hardware problem and nothing to do with software. usually it is bad soldered flash chip. latest mid-range semc phones quality is below zero. as last resort, you can try to raise voltage on FLASH VPP upto 12v (for start, try to flash it with dcu60, it also has increased voltage) but what say to customer if phone works before servicing? have no idea - think yourself- that is risk that you including in each service cost. sadly, but such thing can be happened - flash sector can read good, but fails on erase/write. |
The Following User Says Thank You to roney_nexus For This Useful Post: |
02-22-2010, 21:42 | #14 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 396 | Quote:
use cid49 100% this problem | |
02-22-2010, 21:49 | #15 (permalink) |
Member: 1034869 Status: Offline Thanks Meter: 9 | trying with CID49 and CID51 same problem!!!! k800 / cid49 / r1ed001 / R1ED001_S_E_EUROPE_fs.ssw.cry R1ED001_1250210_GENERIC_WI.ssw.cry RUNNING v0.915060/UNI CARD SERIAL 000**** PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 SIGNED MODE (USING SERVER) CFG:100100000000 SERVER CREDITS LEFT/USED: 13/17 CARD COUNTERS: FLASH 19, UNLOCK 42 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:355704019***** CERT:BROWN FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "D:\gsm2008\SETool3\k800\R1ED001_1250210_GENERIC_W I.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 13 secs. k800 / cid51 / r1jc002 / R1JC002_FS_S_E_EUROPE_WI_RED_CID51.ssw SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:355704019***** CERT:BROWN FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "D:\gsm2008\SETool3\k800\R1JC002_FS_S_E_EUROPE_WI_ RED_CID51.ssw" CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 4580 HDR block not accepted,error: 19 Elapsed: 11 secs. |
K800 Cid 49 Brown To Red | Nasmi | DreamBox | 1 | 06-17-2008 10:52 |
K800 Cid 49 Brown To Red | Nasmi | Cruiser Suite | 1 | 06-17-2008 09:17 |
k800 cid 49 imei help me please | gessebsb | Universalbox | 2 | 10-17-2007 00:50 |
k800 cid 49 red blinking | kaiserstumm | Sony Ericsson | 1 | 08-25-2007 14:16 |
