sony Z550a 2pec lock to videotron sim restore unlock done via setools phone CID 51 insert orig sim card goto unlock repair and run restore files unlock done my usb cable and Drivers Files here my restore Files R6GA004_CXC1250583_GENERIC_ML here logs http://i334.photobucket.com/albums/m...titled-141.jpg http://i334.photobucket.com/albums/m...rtega/4343.jpg v0.915056/UNI CARD SERIAL: 000**** Loaded 51 flash descriptors CFG:000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501479484 CERT:RED FLASH CID:51 COLOR:RED Model (from GDFS):Z550a Brand:Videotron MAPP CXC article: R6GA004 prgCXC1250583_GENERIC_ML MAPP CXC version: R6GA004 Language Package: ROGERS CDA article: CDA102731/35 CDA version: R2A Default article: cxc1250506 Default version: R6GA004 PROVIDER: 302-72 Network LOCKED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 6 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501479484 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID:897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM39 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 Starting embedded bootloader... INT LDR:DB2010_RESPIN_ID_LOADER_SETOOL2 LDR:DB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID:897E UPLOADING REST FILE "D:\BACKUP 1\SE TOOLS\rest\R6GA004_CXC1250583_GENERIC_ML"... Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 143 secs. http://i334.photobucket.com/albums/m...a/SNC00015.jpg http://i334.photobucket.com/albums/m...a/SNC00019.jpg http://i334.photobucket.com/albums/m...a/SNC00016.jpg |
i have same model here.... in identify its showing me simlock-status is NOT DETECTED.........i also posting the logs here CFG:000000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501307437 CERT:RED FLASH CID:51 COLOR:RED Model (from GDFS):Z550a Brand:Fido MAPP CXC article: R6GA004 prgCXC1250583_GENERIC_ML MAPP CXC version: R6GA004 Language Package: ROGERS CDA article: CDA102731/14 CDA version: R10A Default article: cxc1250506 Default version: R6GA004 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. |
