02-26-2010, 07:58 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | V630 to K610i unlock done Code: PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35194101099452 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "F:\(2) Ufs Flasher files\(01) BOX'S TOOLS\S E tool\Flash Files SETOOL\K610i Cid49\R1ED001_1250374_GENERIC_TH.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 Will flash 455 blocks... writing "F:\(2) Ufs Flasher files\(01) BOX'S TOOLS\S E tool\Flash Files SETOOL\K610i Cid49\R1ED001_M_EAST_N_AFR_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 2180 Will flash 109 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed resetting usercode.. USERCODE RESET TO "0000" using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 434 secs. SIGNED MODE (USING SERVER) CFG:100111000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35194101099452 CERT:RED FLASH CID:49 COLOR:RED Model (from GDFS):K610i Brand:Generic MAPP CXC article: R1ED001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1ED001 Language Package: M_EAST_N_AFR CDA article: CDA102514/2 CDA version: R2A Default article: cxc1250376 Default version: R1ED001 PROVIDER: 234-15 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 31 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111111000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35194101099452 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM27 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Starting embedded bootloader... INT LDR:DB2020_PRELOADER_FOR_SETOOL2 LDR:DB2020 LOADER FOR SETOOL2 FLASH ID:897E FOUND VERSION "R1ED001_CXC1250374_GENERIC_TH" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 123 secs. |
The Following 5 Users Say Thank You to Shakeel_pattoki For This Useful Post: |
thanks to setool team T715 cid53 unlock done few second free | kadricom | SETool2 | 6 | 02-16-2011 10:38 |
k610i white screen and k320 unlock done w/o credit | venuno | SETool2 | 1 | 10-20-2009 16:04 |
Unlock V630 and K610i | guty | Cruiser Suite | 6 | 03-16-2008 22:16 |
Can we convert K610 to K618i and V630 to K618i? | hooi76 | Cruiser Suite | 4 | 01-14-2008 10:49 |
[K610i]Unlock not done | Seifter | KULANKENDI Server | 2 | 01-05-2008 20:28 |
