08-12-2008, 07:50 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: india.coimbatore Age: 47
Member: 233492 Status: Offline Thanks Meter: 93 | W200 unlocking probilem/SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. CARD SERIAL: 00043*** Loaded 51 flash descriptors Open COM port OK Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 5 secs. ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402536898 CERT:RED FLASH CID:52 COLOR:RED Model:W200i Brand:Orange MAPP CXC article: R4GB001 prgCXC1250725_ORANGE_ME MAPP CXC version: R4GB001 Language Package:ORANGE_GEN CDA article: CDA102738/71 CDA version: R9A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 234-33 Network LOCKED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4GB001_CXC1250725_ORANGE_ME" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 156 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402536898 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 Flash ID check:2019 Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM5 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 132 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. RECOVERY MODE STARTED NEW SECURITY (MARITA RESPIN) PHONE REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A Fetching phone data from OTP OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402536898 CERT:RED THAT WILL KILL YOUR PHONE, ABORTED Elapsed: 5 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402536898 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 Flash ID check:2019 Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM5 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 96 secs. |
08-12-2008, 08:13 | #2 (permalink) | |
Freak Poster Join Date: May 2006
Member: 275590 Status: Offline Thanks Meter: 41 | What Sim card u used? Setool test card or same brand of mobile(orange,T-mobile,O2,etc.........) ? which one u used? Quote:
08-12-2008, 08:20 | #3 (permalink) | |
Member: 275590 Status: Offline Thanks Meter: 41 | hi Hi, Sorry use orange Sim card brother. Since ur brand i orange i think.... Quote:
08-12-2008, 09:11 | #4 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Romania Age: 52
Member: 563582 Status: Offline Thanks Meter: 42 | RESTORATION FILE NOT PRESENT ! First of all make restoration file, and use Orange (PROVIDER: 234-33) sim card or TEST CARD! If you already make something wrong and your phone not accept any sim card restore security backup an try again ! |
08-12-2008, 15:54 | #5 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Unknown
Member: 603971 Status: Offline Thanks Meter: 730 | RESTORATION FILE NOT PRESENT "R4GB001_CXC1250725_ORANGE_ME" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED chek this massage you can understant |
"sim card not present in phone" w850 i | littie_nettie | SETool2 | 8 | 01-10-2014 10:18 |
ERROR: PM120 field not present in 6500s phone (SL2) | Ros_GSM | Nokia Base Band 5 ( BB-5 ) | 5 | 08-31-2009 19:03 |
N72 ape mcu not present in phone | DIDIER2009 | Nokia Base Band 5 ( BB-5 ) | 3 | 07-10-2009 19:59 |
N95 ape mcu not present in the phone | MIKE2000 | Nokia Base Band 5 ( BB-5 ) | 5 | 05-15-2009 22:13 |
SIM Cards from 3 in GSM phones | kaseby | Sim Cloning and Scaning | 1 | 11-17-2005 15:32 |
