12-24-2011, 08:29 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: PAKISTAN
Member: 233108 Status: Offline Sonork: 100.1587561 Thanks Meter: 86 | W20i UNLOCK FAILED BUT LOSS THE 5 CREDITS PLS HELP ME CFG:100010000000 SERVER CREDITS LEFT/USED: 25/5 CARD COUNTERS: FLASH 1395, UNLOCK 343 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200041777 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 20/10 CARD COUNTERS: FLASH 1395, UNLOCK 343 Elapsed: 2 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01238200041777] OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200041777 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 7 secs. |
12-24-2011, 08:38 | #2 (permalink) |
Freak Poster Join Date: Jul 2008 Location: pakistan
Member: 819109 Status: Offline Sonork: 100.1590081 Thanks Meter: 132 | w20i unlock fail don't worry My dear , server is down , when server will be back your phone will be unlocked free , i mean when you will unlock this phone it will not consume More credits . |
12-24-2011, 08:40 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gsm_World
Member: 583353 Status: Offline Thanks Meter: 259 | Try this Method post result... CID 80 & 81 try this Method.. Need 5 Logs to Unlock this set MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. 1. Select Proper Modle From List & Go to Setting Option 2. Select Sign Mode 3. Perform Full Unlock Instead User Code Reset 4. Disable Flash Mode Activation For Semc A2 Phones 5. Press Unlock 6. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. br, |
12-24-2011, 08:45 | #4 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Quote:
5.PERFORM;FULL UNLOCK;INSTEAD OF;USER CODE RESET; 6.DISABLE FLASH MODE ACTIVATION FOE SEMC A2. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and | |
12-24-2011, 09:45 | #5 (permalink) | |
Freak Poster Join Date: Apr 2001 Location: Europe,Slovakia Age: 50
Member: 4354 Status: Offline Thanks Meter: 55 | Quote:
12-24-2011, 10:46 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | i have same probilem PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200267369 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 16 secs. |
12-24-2011, 10:53 | #7 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: PAKISTAN Age: 39
Member: 181886 Status: Offline Sonork: 100.1579817 Thanks Meter: 1,007 | Quote:
12-24-2011, 10:53 | #8 (permalink) | |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Quote:
CID 80 & 81 try this Method.. Need 5 Logs to Unlock this set MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. 1. Select Proper Modle From List & Go to Setting Option 2. Select Sign Mode 3. Perform Full Unlock Instead User Code Reset 4. Disable Flash Mode Activation For Semc A2 Phones 5. Press Unlock 6. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. | |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
12-24-2011, 11:00 | #9 (permalink) | |
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200267369 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM69 PHONE READY TO PROCEED. GOT SEED:004418FE ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Quote:
thks bro my probilem slove | |
12-24-2011, 11:02 | #10 (permalink) | |
Junior Member Join Date: Aug 2011 Location: Hell
Member: 1632921 Status: Offline Sonork: 100.1606684 Thanks Meter: 4,294,967,295 | Quote:
check signmode + alternate bypass + full unlock | |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
