11-17-2014, 11:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | w20i unlock problem CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01253000795752 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM21 Phone not responding to AT #1, retry 1 Phone not responding to AT #1, retry 2 Phone not responding to AT #1, retry 3 Phone not responding to AT #1, retry 4 Phone not responding to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 61 secs. |
11-17-2014, 14:53 | #3 (permalink) |
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | probleme solved unlock donne 17/11/2014 14:27:47 RUNNING v 1.1408/01.15/UNI 17/11/2014 14:27:47 CARD SERIAL 00153900 17/11/2014 14:27:47 USBFLASH DRIVER VERSION 02.02.00.05 17/11/2014 14:28:13 SIGNED MODE (USING SERVER) 17/11/2014 14:28:13 CFG:101000000000 17/11/2014 14:28:25 ChipID: F100, EMP protocol: 0401 17/11/2014 14:28:25 PHONE DOMAIN: "RETAIL" 17/11/2014 14:28:25 PHONE CID: 0081 17/11/2014 14:28:25 17/11/2014 14:28:26 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01253000795752 CERT:RED 17/11/2014 14:28:26 LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 17/11/2014 14:28:26 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH 17/11/2014 14:28:27 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 17/11/2014 14:28:27 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA 17/11/2014 14:28:27 writing "D:\setool\flash\w20\R7CA058.APP_SW_1232_9903_GENE RIC_TO_REDBROWNBLUE_CID81_80_53_52_49_DB3350.SOFTW ARE" 17/11/2014 14:28:37 ALLOWED DOMAINS: BLUE BROWN RED 17/11/2014 14:28:37 MAXIMUM CID: 81 17/11/2014 14:28:37 Will flash 1007 blocks ... 17/11/2014 14:30:44 SSW file accepted 17/11/2014 14:30:44 writing "D:\setool\flash\w20\R7CA058.FS_M_EAST_N_AFR_TO_RE DBROWNBLUE_CID81_80_53_52_49.SOFTWARE" 17/11/2014 14:31:23 ALLOWED DOMAINS: BLUE BROWN RED 17/11/2014 14:31:23 MAXIMUM CID: 81 17/11/2014 14:31:24 Will flash 2563 blocks ... 17/11/2014 14:36:52 SSW file accepted 17/11/2014 14:36:55 using GENERIC phone customization 17/11/2014 14:36:55 tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm 17/11/2014 14:36:56 tpa/preset/custom/FM_PICTURES_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/FM_SOUNDS_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/FM_THEMES_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/FM_VIDEOS_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/GAMES_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/MC_MUSIC_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/MC_PHOTO_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/MC_VIDEO_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm 17/11/2014 14:36:56 tpa/preset/custom/preloaded_config.xml 17/11/2014 14:36:57 tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm 17/11/2014 14:36:57 tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm 17/11/2014 14:36:57 tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm 17/11/2014 14:36:57 tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm 17/11/2014 14:36:57 tpa/preset/custom/Customize.xml 17/11/2014 14:36:58 Elapsed: 525 secs. 17/11/2014 14:38:20 SIGNED MODE (USING SERVER) 17/11/2014 14:38:20 CFG:101000000000 MODE (USING SERVER) 17/11/2014 14:40:51 CFG:100011000000 17/11/2014 14:40:57 ChipID: F100, EMP protocol: 0401 17/11/2014 14:40:57 PHONE DOMAIN: "RETAIL" 17/11/2014 14:40:58 PHONE CID: 0081 17/11/2014 14:40:58 17/11/2014 14:40:58 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01253000795752 CERT:RED 17/11/2014 14:40:59 LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 17/11/2014 14:40:59 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH 17/11/2014 14:41:00 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 17/11/2014 14:41:00 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA 17/11/2014 14:41:00 Executing CSCA-based unlock. 17/11/2014 14:41:00 Checking for signature ... 17/11/2014 14:41:00 signature found, skipping calculation 17/11/2014 14:41:00 Backup security data ... 17/11/2014 14:41:01 Erasing locks ... 17/11/2014 14:41:02 17/11/2014 14:41:02 DISCONNECT PHONE NOW 17/11/2014 14:41:02 REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 17/11/2014 14:41:02 INSTALL PHONE MODEM DRIVERS IF NEEDED 17/11/2014 14:41:02 17/11/2014 14:41:02 SEARCHING FOR PHONE, "STOP" TO ABORT 17/11/2014 14:41:52 PHONE FOUND AT COM21 17/11/2014 14:42:00 PHONE READY TO PROCEED. 17/11/2014 14:42:34 GOT SEED: 00C4E2BF 17/11/2014 14:42:36 ACTIVATION COMPLETED. USERCODE RESET TO "0000" 17/11/2014 14:42:36 DO NOT DISCONNECT PHONE FROM CABLE 17/11/2014 14:42:36 UNTIL PHONE TURNS ON BY ITSELF 17/11/2014 14:42:37 Unlock DONE |
