08-03-2008, 05:06 | #3 (permalink) |
Banned Join Date: May 2007 Location: In your Heart
Member: 503816 Status: Offline Thanks Meter: 224 | sir when i connect vcc and gnd and data cable so spay was not succeeded but when i remove vcc and gnd then after click on spay defined the soft finds txd and rxd sir please advise me the solution for this problem |
08-04-2008, 02:56 | #4 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 811759 Status: Offline Thanks Meter: 14 | Quote:
If not, it is quite possible that it will make a mistake in it. | |
10-29-2008, 06:58 | #7 (permalink) |
No Life Poster Join Date: Aug 2005 Location: SILIGURI Age: 46
Member: 170589 Status: Offline Thanks Meter: 1,848 | using the battery power spy define will not work, we must use box power to spy define, when we use box power the +ve and -ve power matches the -ve and -ve power matches which comes from cable. we can use battery power to work after spy define, sometimes after spy define it work without battery and box power |
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems | GsmMunna | HWK | 1801 | 05-18-2023 13:08 |
unlocking 8350i problem [ANSWERED] | NeeMan | PolarBox 3 | 5 | 03-29-2010 19:21 |
POTATO interfeis problem | lipen | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-29-2010 17:01 |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
