Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 03-12-2016, 03:34   #61 (permalink)
Member: 1296452
Thanks Meter: 67
i need htc 526g+ firmware above link not working kindly post working link
Old 03-12-2016, 07:48   #62 (permalink)
kathir.'s Avatar
Member: 880497
Thanks Meter: 197
Use that link given by kavithamobiles.....it s working fine
The Following User Says Thank You to kathir. For This Useful Post:
Old 03-17-2016, 12:46   #63 (permalink)
Member: 1024748
Thanks Meter: 53
dear james brooo i got a phone only vibrating after flash... trying to flash with sp tool
but not taking flash.... while format + download got error 6047. help bro
Old 03-17-2016, 14:17   #64 (permalink)
Member: 2547332
Dear James,
I Have a problem (Bootloop) and both of fastboot and recovery are not work,
when I select fastboot or recovery the device restart
Old 03-28-2016, 13:09   #65 (permalink)
sb99sameerkhan's Avatar
Member: 1978625
Sonork: 100.1661449
Thanks Meter: 39
set is dead sp tool erorr this file htc desire 526G+
Old 03-29-2016, 10:13   #66 (permalink)
Member: 2403165
Dear James cant we flash the original sense OS for this phone now a days some of the mtk devices got original sense ui please find out and help us cheers
Old 03-30-2016, 10:15   #67 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Thumbs up HTC DESIRE 526G+ DUAL SIM HANG LOGO OR unfortunately has stopped ERROR SOLVED
Originally Posted by kavithamobiles View Post
Hi this file sd card support zip no need flash with flash tool all credits to jamesjerss
https://mega.nz/#!gtUjGCLb
Decryption key :!_bstuGRT8Bjjd1NbZlATb5OJNVzmF0zSWqeJnR_20gM
Why u flashing with sptool this file support sdcard
THANK BRO YOU RIGHT SAYS. SD CARD UPDATE BATTER OPTION NO DEAD RISK. I AM 2 HANDSET UPDATE SUCCESSFUL.
HERE IMAGE STORY
DOWNLOAD FIRMWARE COPY & PUT MEMORY CARD_ 1.05.720.1-Sd Card Update By Sridhar Chakrala
The Following 3 Users Say Thank You to .::THE ROCK::. For This Useful Post:
Old 04-04-2016, 05:36   #68 (permalink)
Member: 2403165
Hi James can i have Build: 1.02.720.1 for HTC deisre 526g+ thanks
Old 04-08-2016, 08:52   #69 (permalink)
Member: 805201
Sonork: DB88-6CEF
Thanks Meter: 8
Wink htc desire 526G+ dead after flash
plz help.flash sp tool mobile dead.before flash just hang condition.
Old 04-08-2016, 14:22   #70 (permalink)
kathir.'s Avatar
Member: 880497
Thanks Meter: 197
See the Above posts flashing vai SD card is safe.....
Dont use sp flashtool
Old 04-10-2016, 19:44   #71 (permalink)
Member: 2464111
Sonork: 100.1671169
Thanks Meter: 16
Yes flash via sd card is safe so don't use sp flash tool flashing via tool phone starts vibrating, guys use sd update for this model....
Sent from my GT-I9105 using Tapatalk
Old 04-16-2016, 08:22   #72 (permalink)
Member: 2547659
Thanks Meter: 3
hello
to flash via sd card the phone has to go to recovery mode. but if it doesent go to recovery mode what will be the option??
we all tried to flash with sp tool and now got stuck
s_ security_secure_usb_DL_image_hash_fail (6047).. now the phones just vibrates, no recocery mode , no htc logo..
Old 04-18-2016, 10:04   #73 (permalink)
Member: 1740101
Sonork: 100.1641580
Thanks Meter: 11
Originally Posted by jamesjerss View Post
HTC Desire 526g+ MT6592 Stock Firmware
Build: 1.05.720.1 Asia WWE
Sp Tool Flash File: Here
SD Card Flash File: Here Mirror: Link Here Credits:utsav_jayesh
Small OTA Zip: Here
Procedure via Recovery:
* Copy sd flash file to sdcard Boot into recovery mode update the zip.
Procedure via adb sideload:
* Copy sdcard file to adb folder rename the file as rom
* In recovery mode select update via adb
* Connect yur device nd run below dvn cmmd to flash yur device
adb sideload rom.zip
Procedure via Fastboot:
* Copy system-signed.img,userdata-sign & boot-signed-img files to adb
fastboot Driver folder nd run belw gvn cmmds.
fastboot flash system system-sign.img
fastboot flash boot boot-sign.img
fastboot flash userdata userdata-sign.img
Procedure via Spflash tool:
* Extract spflash tool file
* Load scatter file
* Press Download Hold both vol keys nd connect vit usb
__________________________________
file not found when click in link
The Following User Says Thank You to shahjad.alam For This Useful Post:
Old 04-18-2016, 15:28   #74 (permalink)
Member: 1703868
Thanks Meter: 3
what is password? can't unzip
Old 04-20-2016, 18:12   #75 (permalink)
Faisa Farooq's Avatar
Member: 299534
Sonork: 100.1651558
Thanks Meter: 36
dear try this
password is (jame)
Page generated in 0.21156 seconds with 9 queries
