Need stock ics for desire bravo Dear supporter i badly need any region ICS firmware for DESIRE BRAVO ,,, waiting for kind replies ,,, if not plz give me any good link for its CUSTOM FIRMWARE for ICS OR JELLYBEAN along with its CWM file link ,,,,,realy will be apretiated ,,, |
bro,,,,how to flsh this CWM file ,,,? through SD card or anyother method ? or need ROOT before doing update ? waiting for replies ,,:confused::confused::confused: |
Unlock boot loader 1st Rename the recovery file name as recovery (do not change the extension) Flash the recovery via fastboot fastboot flash recovery recovery.img |
this file i have downloaded in winrar form ,,,should i first extract and when i put this file ,,, in my c drive i have make one folder in name FASTBOOT,,,shoulld after extract ,,,keep this file in that folder or some where else ? I know once i understand HOW TO FLASH THIS RECOVERY ,,,will always helpfull for future jobs ,, waiting for your reply |
den flash it via fastboot Guides & tips here |
bro what i understand that i should download CWM file and rename it by RECOVERY.IMG,,,then i must keep it on desktop ,,,ok then i open COMMAND PROMPT and without changing directory ,,,i should simply write this command ,,fastboot flash recovery recovery.img,,,by connecting phone in FASTBOOT,,and simply RUN it ,,, thats it ? Then will take SD card and copy that custom rom in winrar form ,,,without extracking,,,,and simply flash by using CWM recovery ? if all is right ,,,then ok ,,,or if making any mistake ,,,plz correct me,,,waiting for your reply and guidence ,,,, |
Adb fastboot Driver Download Use win7 Yes copy the file to desktop or any where Run command by pressing shift+ right click select open command window here Run the command to flash the recovery Before flash rom full wipe data,cache,system nd delvik cache using recovery |
sir ,,,,,i have window XP ,,,so will same driver work on that ? |
sir in above setup its asking INSTALLING ADB SYSTEM-WIDE Y/N ,,,,what should i give YES OR NO ?????? |
If its asking to click yes den press yes until driver installation get complete If yu re facing prob vit this use this tool http://forum.gsmhosting.com/vbb/f485...eased-1789408/ Put yur mobile in fastboot mode Run the tool Below flashing partition Select recovery Select the file n nxt tab press flash It vil flash recovery Or contact me via yahoo i vil clear yur doubts |
Bro as i told you i was totaly zero in android ,,,after reading your threads in android section ,,,i inspire to learn updating android,,,,as much i understand ,,baicaly android update depends of PROPER INSTALATION DRIVERS as well COMMAND PROMPT using in proper manner,,,i admit have eated your heads ,,,but trust me,,have learned alot of ,,,,and assured you ,,,know will try to learn myself,,,as much as i learn,, and realy sorry to irritae you,,,,but in future not ,,,trust me.:):):):):) |
i jus told yu try yur self little boz yu asked doubt in simple driver installation. |
