HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
12-02-2010, 13:48 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: sylhet
Member: 517801 Status: Offline Sonork: 100.1594355 Thanks Meter: 316 | Android Phones Hard Reset Android Phones - Hard Reset Please post here only Hard Reset of Android Phones No question or how to please. Help me to keep this thread clean "Performing a factory data reset deletes all data, including downloaded applications, and resets the device back to its initial state—the state before you turned on the device for the first time. Important Make sure to back up important data you have on the device before you perform a factory data reset." HTC Dream 1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit. 2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle. Now to wipe the device clean: 3. Press Alt+L. 4. Press Alt+W for a factory reset. 5. Press the Home and Back keys again for about 25 seconds. The device should then reset again and the hard reset is complete. HTC Magic 1. With the phone turned off, press and hold the HOME and BACK 2. Briefly press the END CALL/POWER button while continuing to pressHOME and BACK buttons. 3. When you see the screen with the 3 Android images, release the HOME and BACK buttons, and then press the TRACKBALL. Tip : If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. HTC Hero 1. With the phone turned off, press and hold the HOME and BACKand then briefly press the END CALL/POWER button. The reset process will start after a few seconds. 2. Wait for the phone to finish the reset process and then press MENU. Tip : If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. ++++++++++++++++++++++++++++++++++++++++++++++++++ HTC Tattoo 1. With the phone turned off, press and hold the HOME and BACKand then briefly press the END CALL/POWER button. 2. Press the ENTER button to begin the reset process. Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. HTC Desire : reserved HTC Whitestone : reserved -------------------------------------------------------------- ================================================== ============ -------------------------------------------------------------- HTC Droid Eris Hard Reset Perform a hard reset on your HTC Droid Eris. These steps will clear all data and settings off the device. 1. With the phone turned off, press and hold the Volume Down and Send buttons. 2. Press the Power button. 3. Follow the instructions to complete the hard reset. --------------------------------------------------------------================================================== ============ -------------------------------------------------------------- Motorola Droid To reset your phone to factory settings and erase all the data on your phone, Touch Menu > Settings > Privacy > Factory data reset > Reset phone. Warning: All data on your phone will be deleted. Motorola Droid Hard reset with keys Power off device. Press X key on hard keyboard + power button, then release both buttons. When you see exclamation point press and hold VOLUME UP + CAMERA KEY. You will see Android system recovery menu. With D pad go to data / factory reset, then press CENTER D Pad, then choose Yes. Motorola Dext : Reserved ----------------------------------------------------------------------- ============================================= ----------------------------------------------------------------------- LG GW620 [Eve] Hard Reset To do a hard reset or data reset in LG GW620 aka EVE Enter using Dial pad 3845#*620# From menu select factory reset or whatever you want. ----------------------------------------------------------------------- ================================================== ===== ----------------------------------------------------------------------- Motorola Dext factory reset 1. Holding the Camera button while turning on your phone, 2. When prompted hit the Volume-Down rocker button to go into Recovery Mode. 3. After you get into Recovery Mode, 4. Press ALT+L to reset, then Menu+Back to reboot. ----------------------------------------------------------------------- ================================================== ===== ----------------------------------------------------------------------- |
The Following 3 Users Say Thank You to bappi1 For This Useful Post: |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
