HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
08-22-2009, 12:29 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | how to hard reset s740 or rose 100 |
06-10-2010, 11:58 | #7 (permalink) |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | when the HTC S740 is turned off by holding down the VOLUME DOWN and the CENTER OK buttons at the same time and then quickly pressing and releasing the POWER button without releasing the VOLUME DOWN and the CENTER OK buttons. Once you see a message appear follow the onscreen instructions. HTC Rose S740 Hard reset - Soft reset |
The Following User Says Thank You to mobileclinic For This Useful Post: |
11-18-2010, 20:52 | #8 (permalink) |
Freak Poster Join Date: May 2007 Location: sylhet
Member: 517801 Status: Offline Sonork: 100.1594355 Thanks Meter: 316 | HTC S740 hard reset In HTC S740 manual there is procedure for hard reset that uses program called Clear Storage in order to reinitialize phone. That will not help you if you forgot password or your phone cannot boot. In order to perform real hard reset on this device, you need to connect your phone to power (via mini-USB cable) and turn it off. Once it is off, press D-Pad Center key together with Volume Down key. While holding those two, shortly press power button. You should get white screen with instructions. You can release those two keys and press Volume Up if you are sure that complete deletion is fine with you. Any other key will cancel process and continue with boot. Please notice that if you complete procedure ALL your data stored on mobile phone is gone and there is no way to get it |
The Following 5 Users Say Thank You to bappi1 For This Useful Post: |
02-19-2013, 18:33 | #9 (permalink) | |
Insane Poster Join Date: Nov 2009
Member: 1172949 Status: Offline Sonork: felix Thanks Meter: 7 | Quote:
How To Hard Reset Or Format On Bootup | ::..s@uddin..:: | Nokia Base Band 5 ( BB-5 ) | 0 | 07-31-2009 11:22 |
How to hard reset cingular 2125 by htc to get rid of usercode? | MR.PRESIDENT | HTC & Smartphones ( WM Without Touch) | 5 | 06-10-2009 17:24 |
O2 Xphone II, How to Hard Reset? Plz Help!! | citifone | HTC & PDA WM( With Touchscreen) | 8 | 01-04-2007 15:28 |
How to hard reset a 7650 ! ! ! I don't know if this is any help ! | email_me_links | WD2 & APE (Symbian Phones) | 6 | 12-01-2004 18:49 |
