HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
02-07-2010, 22:05 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | i780 ROM & Flashing Guide PDF File: http://rapidshare.com/files/22818959...hing_Guide.pdf Files Needed: 1. Samsung USB Driver: http://rapidshare.com/files/22819049..._WHQL_v3.4.exe 2. Russian ROMS: http://www.4shared.com/file/63104055...HE1_Rev12.html 3. E1 English PDA ROM: http://rapidshare.com/files/13151206...DXHE1.rar.html 4. Mirage Updater: http://rapidshare.com/files/22819176...ge_LV_v1.8.exe for best results flash using Windows XP Enjoy |
The Following 20 Users Say Thank You to delower10 For This Useful Post: |
02-08-2010, 12:17 | #2 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Bali Island - Indonesia
Member: 589534 Status: Offline Thanks Meter: 251 | Quote:
thanks. | |
02-08-2010, 14:48 | #3 (permalink) | |
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Quote:
i780PUHE1.7z i780_PUHE1_Rev12.img | |
02-08-2010, 15:55 | #4 (permalink) | |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | Quote:
some link not working.............. plz uplode agian | |
02-08-2010, 16:05 | #5 (permalink) | |
Thanks for ur report only Russian ROMS Error #2 is Russian ROMS: tomorrow it will be ok other link working | |
The Following User Says Thank You to delower10 For This Useful Post: |
02-12-2010, 19:25 | #7 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | pls i have download this files..pls how to connect this phone my phone is in netherlands language i need english on it..how to connect for flashing/..br?? |
02-14-2010, 05:25 | #10 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Press any phone number and dial, phone should turn radio on or ask for permission. |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
02-16-2010, 12:22 | #11 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | i do its not help ...now i reflash now work fine...correcetion i flash english rom in phone tab instead of pda i read flashing guide now ..all is done ..thanks u guys u re realing help..br |
03-14-2010, 15:01 | #13 (permalink) |
Freak Poster Join Date: Sep 2004 Location: algeria Age: 48
Member: 81788 Status: Offline Thanks Meter: 9 | Flashing Guide To update your i780, PLEASE OBSERVE AND FOLLOW as below: If you have not flashed your i780 with DXHE1 ROM, you MUST do the following FIRST, But if you ALREADY have DXHE1 on your i780, you can skip the Russians rom: Here are the full Instructions on how to get E1 English firmware on your Samsung i780 You NEED: - Windows XP SP2 with ActiveSync 4.5 (Mirage Updater CAN'T run under Vista for now) -Samsung USB drivers from RapidShare: 1-CLICK Web hosting - Easy Filehosting (Updated Download Link) -Samsung USB Cable To be on the safe side,make sure your battery is fully charged but 60% charge worked fine so far Please refer to download links in the updated section FIRST, if you are NOT already running DXHE1, you must do this: (0) Download Mirage Updater (1) Download the Russian ROMS (2) Download the E1 English PDA ROM (3) Switch off your phone and remove the battery, then insert the battery (4) Extract the two files downloaded in steps 1,2,3 in the same directory (5) Launch Mirage updater. Select MIRAGE LV image as the profile (6) Select EBOOT+PDA+PHONE and select the extracted RUSSIAN .img file (7) Click on DETECT (8) Switch on the phone while holding the ENTER and FUNCTION buttons (ALT BUTTON) (9) After the system DETECT message appears, connect the phone via USB to your PC (10) Wait until the image is written. Repeat steps 3-10 the process for the E1 english PDA ROM. i.e the .bin file However, this time, for step 6 select PDA in Mirage updater and Your phone should be working in no time. PDA Version: i780DXHE1 Phone Version: i780PUHE1 If you have done the above, it's time to upgrade to WM6.1. - Same steps as above, run Mirage Updater: - Same as step 6 above, select PDA in Mirage updater - Select i780_WM6.1_EFNV3.0.bin - Wait until Mirage Updater finishes checking the bin file - Press Detect - Take OUT the battery (MUST!) and then put it back - Switch on the phone while holding the ENTER and FUNCTION buttons (ALT BUTTON) - Wait until you see the boot shows some messages - Then Plug in the USB cable - It should begin downloading automatically and once done you can disconnect your i780 - DONE! |
i780 , i907 & Omnia i900 Free unlock | moulnisky | NSPRO | 2 | 03-29-2009 20:37 |
i780 , i907 & Omnia i900 Free unlock | rana_sab | HTC & Smartphones ( WM Without Touch) | 1 | 03-28-2009 17:39 |
i780 , i907 & Omnia i900 Free unlock | lemor | HTC & PDA WM( With Touchscreen) | 13 | 01-18-2009 22:06 |
Benq e72 Flashing ROM & More general help | djkee | HTC & Smartphones ( WM Without Touch) | 0 | 01-15-2009 07:02 |
AX72 Flashing with joker guide & flash file | emchido | S-Gold Based Phones | 5 | 04-17-2007 17:26 |
