HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
08-02-2005, 04:30 | #168 (permalink) |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | my email add is [email protected] or you can have it posted here ir so that everyone can see it... tnx a lot again |
08-02-2005, 06:30 | #172 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 44
Member: 98719 Status: Offline Thanks Meter: 336 | I'll try getting that file. My ICQ number is 234-796-186 If you're trying to add me to your ICQ list, on the message area, type "GSM-FORUM". I get a lot of spammers so, this is the easiest way to filter these guys out. |
08-03-2005, 05:18 | #173 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | Resco System Toys for SmartPhone v1.20 Application Description Resco System Toys is a set of 2 useful and easy to use tools. One is Battery state and second is Task manager. Battery State is small utility which display state of your battery state of your internal memory state of all storage cards Task Manager is the way to control your SmartPhone applications the tool to easily close or switch to any running application |
The Following User Says Thank You to charlielao For This Useful Post: |
08-03-2005, 05:26 | #174 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | Oxios ToDo List - Outlook Tasks 5.0 Summary: With Oxios ToDo List you will be able to create, fully edit and modify tasks on Smartphone and synchronize it with Outlook. Key Features: * 12 (compressed view) or 6 (full view) tasks per page. * Quick entry bar (could be hidden) * Preview pane function (could be hidden) * Notify icon when one task start/end today * Icon chooser for the tasks list * Set of standard views : All Tasks, Overdue Tasks, Active Tasks, Completed Tasks, Today, Next 7 Days, Future Tasks, Undated Tasks. * Category filter (Multi-Categories allowed). * Quick navigation in views (with Shortcuts). * Three-level task sorting in ascending or descending order (Priority, Status, Subject, Dates...). * Task Summary. * Default values for new tasks. * New reminder management (no more alarms at 8:00 AM even on due date). * Fully customize the button asignments. You can change the priority or mark a task complete with one press. * Send support (IR, Bluetooth, Email, Save as...). * Insert Support (Predefined Text, Contact, Call History) * Multilingual User Interface support (English, German and French). * Intuitive date input (just like Outlook). * Recurring task support. * Full category support with category icons. * Customize the colors to show task status (e.g. Overdue, Completed etc.). * Multiple font size and style support. * Compatible with Oxios Plugins (Smartphone Home Screen). * Synchronization with Microsoft Outlook. Oxios ToDo List Compatibility and Requirements * Windows SmartPhone 2002, 2003 or 2003 SE. * 380 KB free storage space required. * Microsoft Windows with Microsoft ActiveSync 3.5 or later. * Microsoft Outlook 2000, 2002/XP or 2003 |
08-03-2005, 05:37 | #175 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | Inbox Speed Reader (Smartphone) 1.0 Inbox Speed Reader allows you to read your inbox items (eMail, SMS) on your Smartphone at amazing speeds using RSVP and ColorBar (patent pending) technologies (~500 WPM for new text and ~1000 WPM when flash reviewing text). A perfect solution for reading long messages on small screens. Inbox Speed Reader is ideal for its productivity value. ColorBar Technology (patent pending) This software uses RSVP technology allowing you to read faster from your PocketPC. To enhance your reading experience, Inbox Speed Reader also uses its own ColorBar technology. The ColorBar will gradually change color as each word in the sentence is displayed, giving you a sense of the word's location in the sentence. At high reading speeds, the ColorBar will appear to pulse as you acquire the thought of each sentence. Using the ColorBar will make your reading experience more fluid and comfortable. Other Key Features: *Quickly read Inbox messages on your Smartphone *Sort message by Sender, Read, Unread and Date & Time *Mark messages with attachments for download *Display/hide message date and time quickly by moving the action button left or right *"Flash Review" important messages that you have already read, before important meetings or tests *Search an entire message for specific text *Easily move forward and backward sentence by sentence *Eliminates the need to manually scroll through long text. Thereby, alleviating the sore thumb syndrome know as ?gamers? thumb |
08-03-2005, 06:00 | #176 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | Theme Changer A free utility to change themes, INCLUDING the media player skin and all the system screens etc common in .CAB themes. NEW in V4: a sound event editor, with theme and storage card support. It also supports putting themes on a storage card (Put them in \Storage Card\Application Data\Home\) NEW in V4: support sounds in \Storage Card\Application Data\Sounds\ VISIT: Theme Changer |
08-03-2005, 07:57 | #177 (permalink) |
Member: 98719 Status: Offline Thanks Meter: 336 | Echo Voice Recorder 1.20 A pretty nice recorder for your Smartphone. * regEchoSp.exe is the keygen Finally, you're the master - choose your preferred format and store your recordings to the SD card or to the phone itself. This indispensable voice recorder features: * Secure Digital (SD) card support * ! Selectable audio file format! * *NEW* Improved ergonomics - Phone keys used to Record, Play, Pause, Stop, Rewind *NEW* * *NEW* Append to the existing recording *NEW* * Industry standard wave audio file format * Standard GSM 6.10 speech compression * PCM Modulations: PCM 8Khz 8 bit, PCM 8Khz 16 bit, PCM 11Khz 8 bit, PCM 11Khz 16 bit, PCM 22KkHz 16 Bit * Real time signal strength indication * Excellent technical support * Free lifetime upgrade plan! * Compatible with Dragon and other popular speech to text software * Supreme design quality |
The Following 3 Users Say Thank You to crystalgeyser2 For This Useful Post: |
08-03-2005, 09:34 | #179 (permalink) | |
Junior Member Join Date: Jul 2005 Age: 62
Member: 163255 Status: Offline Thanks Meter: 0 | Quote:
But unfortunately the keygen don't work. | |
08-03-2005, 10:21 | #180 (permalink) | |
Freak Poster Join Date: Feb 2005 Age: 49
Member: 119771 Status: Offline Thanks Meter: 5 | Quote:
yeah but you can also hold the HOME button down and it allows you to swith bluetooth as well as GPRS on or off! | |
Any other good site for cracked smartphone apps/games? | Razor1973 | HTC & PDA WM( With Touchscreen) | 8 | 03-06-2022 03:18 |
Download Caveman xmas editon and other new game here!!! | Special@gsm | Nokia Multimedia | 3 | 02-05-2007 00:55 |
Smartphone Multiplayer Games Here | wormscrazy | HTC & PDA WM( With Touchscreen) | 3 | 01-15-2007 13:38 |
Smartphone Golf Game | fraserhead | Sony Ericsson Media, RingTones, Games | 0 | 05-25-2006 14:01 |
