HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
08-26-2008, 05:58 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Philippines
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | Unlock SPV C500 How? confuse Just because of too many software for c500 unlocking found after searching then i confused. I just want to know if what software to unlock for this version below: Typhoon IPL 1.00 Typhoon SPL 2. 05. 0130 TIA... |
08-26-2008, 11:04 | #3 (permalink) |
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | ---------------disable it Certificate security first-------------- (use motorola testcard to enter in locked phone) upload regeditSTG.zip(extract zip on phone) with activesych or regeditSTG.exe on memory card lauch regeditSTG.exe GO TO HKEY_LOCAL_MACHINE SECURITY POLICIES AGAIN POLICIES press value THEN EDIT VALUES 00001001 TO 1 THEN EDIT VALUES 00001005 TO 40 (thanks celcom) now you have DISABLE Certificate security ----------------------------------------------------------- you could install Cert.cab throw activesync after run SPVServices.exe follow instructions Enjoy!! ps:no need to reboot the mobile ----------------------------------------------------------- ----------------------------------------------------------- ----------------------------------------------------------- After i follow procedure many times above i always got error during installing CERT.CAB Here`s the error (( Installation failed. The program or setting cannot be installed because it is not digitally signed with a trusted certificate )) My problem is, i can`t install CRT.CAB even value was already edited. Any suggestion for this and much appreciated TIA... |
08-26-2008, 21:39 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: THAILAND-CHINA-INDIA-CANADA
Member: 230831 Status: Offline Sonork: 100.98820 Thanks Meter: 278 | make hard reset ur device and try to do process again. br jass |
The Following User Says Thank You to GSM-FUTURE For This Useful Post: |
08-31-2008, 13:40 | #6 (permalink) | |
No Life Poster Join Date: Jul 2005
Member: 163076 Status: Offline Thanks Meter: 97 | if u can't install cert then u must concentrate on following para Quote:
The Following User Says Thank You to Gr8SightMan For This Useful Post: |
09-06-2008, 22:54 | #7 (permalink) |
Junior Member Join Date: Oct 2007
Member: 617589 Status: Offline Thanks Meter: 0 | This will only unlock your applications not the sim. Doesn't unlock the sim. I've tried a hundred different ways and various roms and this method only unlocks applications. Nobody knows how to unlock the sim for an orange spv c600. I asked everywhere on the net and nobody knows bugger all. |
Unlock SPV c500 c550 c600 & other SPV without Internet | PhoneCareCenter | HTC & Smartphones ( WM Without Touch) | 83 | 04-16-2023 14:27 |
how to unlock spv c500 for free???? | svchost | HTC & Smartphones ( WM Without Touch) | 3 | 05-26-2009 18:16 |
how to unlock spv c500 in diferent contry? | KARIM GSM-ZONE | HTC & PDA WM( With Touchscreen) | 4 | 01-16-2006 10:00 |
Unlock SPV C500 orange lock | Fre3 Crack3r | Phone Unlocking Codes & Maps | 8 | 07-06-2005 11:26 |
