PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
![]() | #2656 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2006
Member: 371901 Status: Offline Thanks Meter: 6 | Quote:
Description: ShortCut5 is a PalmOS 5.x preference panel which supports large (up to 4096 characters in size) shortcut definitions. The system shortcuts only supports small (about 45 characters in size) shortcut definitions. ShortCut5 shortcuts are in addition to the system shortcuts. Limitations. Maximum of fifty shortcuts definitions. Each shortcut name is from one to four characters in length. Shortcut names are case sensitive and cannot contain the period "." character. ShortCut5 is only supported on PalmOS 5.x and on locales that use single byte characters. ShortCut5 will not recursively expand shortcut definitions. Instructions. To expand a shortcut, enter a period "." character followed immediately by the shortcut name. Do not change fields or change the insertion point within the same field while entering the shortcut name. App list. This is used to select a list of apps to either enable or disable (based upon the activation options in the Preferences). Activation options in the Preferences. This is used to selectively disable and enable this preference panel. (1) Enable all apps. ShortCut5 is always enabled. (2) Disable all apps. ShortCut5 is always disabled. (3) Disable for app list. ShortCut5 is enabled for all apps except for those in the app list. (4) Enable for app list. ShortCut5 is disabled for all apps except for those in the app list. Optimal performance. For best performance, use the app list and activation options to disable ShortCut5 when executing games or other event intensive (graphics) applications. Notes. The shortcut will expand at a moderate speed (as to not overflow the key queue). | |
![]() | #2657 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2006
Member: 363899 Status: Offline Thanks Meter: 38 | Quote:
![]() | #2658 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 396769 Status: Offline Thanks Meter: 4 | Quote:
1) Menu button then "K" will bring up a virtual keyboard in most applications. 2) For the underscore symbol, use the dash symbol (Option S), then push the Alt key. A list of characters will pop up...underscore should be one of them. You can do this with almost every letter to get differrent variations of the letter. Sorry if this is old news, just throwing it out there as an option. | |
![]() | #2662 (permalink) | |
Crazy Poster ![]() ![]() ![]() Join Date: Nov 2006 Location: TREO 700P
Member: 400913 Status: Offline Thanks Meter: 7 | Quote:
I can confirm that even the new, new updated Opera still has this problem. You cannot bring up a virtual keyboard. And you can't use the Option-S-Alt method either. That's because anytime you type Alt in Opera it types a "?". No idea why, it just has to be a bug. | |
![]() | #2663 (permalink) |
Member: 400913 Status: Offline Thanks Meter: 7 | Man, I'm so happy! Thanks big time, I've been trying to get this for 2 weeks!!! I tested and it work wonderfully! No need for all that USBConnect and tether-mode hacking crap, or of course Sprint's $40/mo plan! Now all I need is the new Telenav for the Treo. |
![]() | #2664 (permalink) | |
Junior Member ![]() ![]() Join Date: Nov 2006
Member: 394344 Status: Offline Thanks Meter: 1 | Quote:
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
