PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
06-16-2008, 06:02 | #10412 (permalink) |
Junior Member Join Date: Dec 2007
Member: 658556 Status: Offline Thanks Meter: 0 | hello guys i just replaced my palm centro cuz it was broken now when i installed butler again i cant register it i know iknow i searched but the existing crack or keygen in the site is not workin for me and i think this is the last version 4.87 can any one plz plz upload me a workin keygen or a way that i can get rid of this naggin registration ---- i know its too much of askin but can any one tell me how can i update my palm? without having an iternet connection on my phone? |
06-16-2008, 06:26 | #10413 (permalink) | |
No Life Poster Join Date: May 2008 Location: C E B U C I T Y
Member: 774786 Status: Offline Thanks Meter: 1,455 | Quote:
try this. enjoy!!!!! http://rapidshare.com/files/12276931...st_KG.prc.html | |
06-16-2008, 08:53 | #10414 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 687934 Status: Offline Thanks Meter: 27 | KINGTYCE After you active the maps you want, do you keep "gmapprom.rgn" in the Garmin folder? What I did, I took out the freebase map and gmapprom.rgn once I got everything working with sw.unl and gmappsupp.unl. (I wanted the entire NA Map unlocked) I placed the Garmin 2009 map NA image in the Garmin folder. Everything runs, but it's so slow ... is this the reason why? b/c i deleted freebase and gmapprom from my Garmin folder? Gonna try and see if NA 2009 map image and "gmapprom.rgn" file left will make things run smooth. But, that's a lot of space .... 1.06GB + 1.7GB BTW what's the code for ONTARIO - CANADA and NEW YORK STATE? Maybe the another reason why my Garmin is running so slow, MY 2009 NA map is so huge. pls & thank you Last edited by E2EK1EL; 06-16-2008 at 09:00. |
06-16-2008, 09:30 | #10415 (permalink) |
Member: 687934 Status: Offline Thanks Meter: 27 | Just looked at the Map_Product ID keygen ... MY *** that thing looks hard! No wonder saj070 is having so many probs. Can anyone generate a code for me pls? Wanna really see if my massive NA 2009 map is causing my Garmin to run ultra slow. MY Device ID - 1081074595 Maps - Ontario Canada & New York State Pls and thank you |
06-16-2008, 11:51 | #10416 (permalink) |
Junior Member Join Date: May 2008
Member: 774843 Status: Offline Thanks Meter: 1 | tealscan 1.1 Here is telescan 1.1 plus keygen use the link to downlaod both http://www.mediafire.com/?9wzgsheufjd http://www.mediafire.com/?hn1mfbv3on9[/quote] i downloaded both, but tealscan.exe_KG doesn't open any ideas??? thanks |
06-16-2008, 13:38 | #10417 (permalink) | |
i downloaded both, but tealscan.exe_KG doesn't open any ideas??? thanks[/quote] drag the exe file to windows command prompt. same as bike or die 2 and the others kg. | |
The Following User Says Thank You to eon For This Useful Post: |
06-16-2008, 16:07 | #10419 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 725754 Status: Offline Thanks Meter: 65 | mundu update It seems yahoo stopped working on Mundu. A new version has been released and fixed the problem. Anyone have a patch to this version? http://www.billsden.org/fileadmin/te...palm_4.1.0.prc |
06-16-2008, 18:59 | #10425 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 453630 Status: Offline Thanks Meter: 1,661 | Quote:
you might want to check which driver you are using... I'm on 42020... I know I had problems with 42030 (resetting my clock and what not) and heard 42040 had issues to.. just a thought... Hmm well I just wanted to post a follow up not sure if this will help since I haven't tried on the streets yet. I went into the settings and by default Garmin had selected "Use GPD Intermediate Driver" which worked for me but again I saw a lag while driving around and frequent redrawing of where I was relative to the map. So now I just went back to the settings and hit "disable" which then brought up a list "Use Bluetooth GPS" "Use GPD Intermediate Driver" and "Use Serial GPS". I then selected "Use Serial GPS" and selected COM4:COM4. I had to do this a couple of times the software would scan but not let me keep COM4 but after a few tries it found COM4. I don't know if this will make everything faster but I will keep everyone posted. | |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
