PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
09-02-2008, 15:25 | #11851 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: Where the Lakers RULE!!!
Member: 631598 Status: Offline Thanks Meter: 267 | Quote:
09-02-2008, 15:39 | #11853 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 453630 Status: Offline Thanks Meter: 1,661 | Quote:
Thanks bud i will start a new thread on front page "NFL 2008" \ i think it going to be hard for people to search which page is has latest NFL 2008 PDB file.. Thanks feces Last edited by saj070; 09-02-2008 at 15:46. | |
09-02-2008, 15:56 | #11854 (permalink) | |
need to copy crack to original file on pc...before you start app.. goto setting register just click ok it will register no need to input anything also delete the word crack from the patch rename it to " RingCareDesktop " same as the one in th program file folder and replace it.. http://www.mediafire.com/?mwqkgu6gjr5 Last edited by saj070; 09-02-2008 at 16:02. | |
The Following User Says Thank You to saj070 For This Useful Post: |
09-02-2008, 16:13 | #11855 (permalink) | |
Freak Poster Join Date: May 2008 Location: Tapping on your Shoulder
Member: 778424 Status: Offline Thanks Meter: 110 | Piloc Universal keygen Quote:
http://rapidshare.com/files/142070358/pilockey.rar | |
09-02-2008, 16:19 | #11856 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: New York where the Giants roam Age: 34
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | Quote:
Let me explain.... The patch does not run by itself. It's a replacement file.... You need to FIRST Install the .exe (RingcareDesktop Installer) on your pc first. It will install all the necessary files needed to run Ringcaredesktop... You then need to copy the cracked file into the ringcare directory... to find it you need to go to your mycomputer folder, then go to local disk c folder, then go program files folder, and then go to ringcaredesktop folder..... once you try to copy the file in ringcaredesktop folder it will ask if you want to replace this file with the next one, choose yes..... now start ringcaredesktop and register with any number/letter. Here is the Installation file and the cracked file for your convenience. http://rapidshare.com/files/14207188...patch.rar.html GOODLUCK | |
The Following User Says Thank You to kingtyce For This Useful Post: |
09-02-2008, 16:20 | #11857 (permalink) | |
/vbb/showthread...04#post3621004 Last edited by saj070; 09-02-2008 at 16:25. | |
09-02-2008, 19:50 | #11859 (permalink) |
Junior Member Join Date: Aug 2008
Member: 849226 Status: Offline Thanks Meter: 0 | Quote: Originally Posted by kingtyce The patched version is not the new version..... You may need to uninstall the newer version completely from your device first if you have installed already..... Then install the patched version from the link. I uninstalled the old version but it still didnt work Has nobody a correct key for QuickIM? |
09-02-2008, 20:50 | #11862 (permalink) |
Member: 778424 Status: Offline Thanks Meter: 110 | Piloc keygen well i tested it on hebrow.prc and it generated a working serial , here is what i got : HEBR-RABS-AARM-327306-GSSUFV type it exactly as above.... in case u need hebrew.prc also here it is: http://rapidshare.com/files/142135068/Hebrew.prc.html piloc.prc : http://rapidshare.com/files/142135550/PiLoc.prc.html Last edited by T.E2; 09-02-2008 at 21:00. |
The Following User Says Thank You to T.E2 For This Useful Post: |
09-02-2008, 21:12 | #11863 (permalink) |
Member: 778424 Status: Offline Thanks Meter: 110 | |
09-02-2008, 21:21 | #11864 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Minneapolis Age: 44
Member: 745572 Status: Offline Thanks Meter: 65 | Hey man..sorry to hear about the loss. Hopefully we get you back on here soon. Give thanks. Peace and love. Waj |
The Following User Says Thank You to superwaj For This Useful Post: |
09-02-2008, 21:32 | #11865 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Around
Member: 416272 Status: Offline Thanks Meter: 1,095 | Quote:
Plumber Pete Extreme is Free... http://www.clickgamer.com/moreinfo.h...1§ion=PALM RS | |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
