PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
09-12-2008, 23:43 | #12451 (permalink) | |
No Life Poster Join Date: May 2008 Location: C E B U C I T Y
Member: 774786 Status: Offline Thanks Meter: 1,455 | Quote:
is this the codes generated: par3: 40675 par72: 40575 try also this: par3: 52760 and par 72: 52670 download a trial from pocketgear and use those files to reg this codes. goodluck. or try to used the attached trial. Last edited by eon; 09-12-2008 at 23:52. | |
The Following User Says Thank You to eon For This Useful Post: |
09-12-2008, 23:54 | #12452 (permalink) | |
par3 here: http://rapidshare.com/files/14479514...m1_04.zip.html | |
09-13-2008, 01:28 | #12454 (permalink) |
Junior Member Join Date: Jul 2008
Member: 826299 Status: Offline Thanks Meter: 8 | HotSync Notifier File Question So I had been trying to make BackupBuddy work for me and it was a no go... no worries, fine, whatever... I uninstalled it it seemed to uninstall cleanly and no remnants remain that I can find, but and now I am getting the following HotSync Manager Message in a dialogue box everytime I start-up HotSync Manager: --------------------------- HotSync Manager --------------------------- The Notifier file 'C:\PROGRA~1\BACKUP~1\BackupBuddy.dll' was not found. Notifers are used by HotSync Manager to inform other applications about synchronizations sessions. Please check your configuration to correct this problem. HotSync Manager is skipping over this file. --------------------------- Anyone have any idea how I can stop this... Many thanks guys... |
09-13-2008, 03:05 | #12458 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: South India
Member: 383590 Status: Offline Thanks Meter: 197 | Quote:
When the TreoLaincher is running you can type in the firdt few letters of the application you want for example "is" and then you will see applications beginning with the alphabets "is" only and if in my case you have only iSilo, it automatically gets launched. Also to navigate you press the side keys and then press the centre button to select. I hope I have been able to help you some bit. | |
09-13-2008, 03:10 | #12459 (permalink) | |
4 questions to you please. What have you used to overclock the Tre 650? To what level have you done so? Are there any particlar applications oyu have overclocked and left others same or underclocked? Has overclocking affected the battery performance markedly? Grateful if you could share your experience. Thanks | |
09-13-2008, 03:29 | #12460 (permalink) |
Freak Poster Join Date: May 2008 Location: Tapping on your Shoulder
Member: 778424 Status: Offline Thanks Meter: 110 | i think battery life on centro is slightly better than tero 680 due to smaller screen although somehow its lower in capacity , 1150 mAh vs. 1200 mAh Last edited by T.E2; 09-13-2008 at 03:38. |
The Following User Says Thank You to T.E2 For This Useful Post: |
09-13-2008, 03:48 | #12462 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Around
Member: 416272 Status: Offline Thanks Meter: 1,095 | Quote:
If you know how to make changes safely within the registry or are willing to take the chance, let me know & I can point you to where in the registry the entry most likely is. RS | |
09-13-2008, 04:03 | #12463 (permalink) |
Member: 778424 Status: Offline Thanks Meter: 110 | overclocking/underclocking hey guys , there are some programs that can overcloc/underclock palm's cpu and almost all of them are posted here before but i thought its good to have them all in one link so here you go . . . enjoy! LightSpeed , Pxa Clocker and WrapSpeed : http://rapidshare.com/files/14483315...-WrapSpeed.rar |
09-13-2008, 05:19 | #12464 (permalink) | |
Freak Poster Join Date: Mar 2008
Member: 736909 Status: Offline Sonork: treo680 2.12-APR Thanks Meter: 77 | Quote:
The Following User Says Thank You to chew For This Useful Post: |
09-13-2008, 06:32 | #12465 (permalink) |
Junior Member Join Date: Jun 2008
Member: 784935 Status: Offline Thanks Meter: 12 | Tradesman App Thanks alot eon for the uploads! Just wanted to keep a post for "Tradesman" around as well so everyone can give a crack at this one too. Thanks in advance |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
