11-07-2018, 10:40 | #1 (permalink) |
Junior Member Join Date: Jul 2018 Location: Los Angeles
Member: 2849208 Status: Offline Thanks Meter: 6 | How To Root Android Using Rootkhp How To Use Rootkhp To Root Android 7.0 Smartphones If you are an Android nougat user who is looking for a rooting tool, my suggestion is to use the Rootkhp tool. Personally, I thought to share about this with you all as it worked properly. It is essential to state that I was new to Android rooting and I have not any previous experiences. But want to state that I refer some youtube videos, guides, and some tutorials before executing the process. I Decided to Root my Nougat Using Rootkhp Tool Hope you all know that in the normal condition you can not alter or change system files and there are some restricted areas which we can not even enter or access. I was dreaming to play one of the apps which I can not find from the google play. Finally, I decided to root my beloved Nougat using the rootkhp tool. It was successful. So, I decided to share my experience with you all. Get Ready Rootkhp Compatible Platforms This tool is compatible only with the Windows platform. As per the description, the tool is compatible with windows vista, Windows 7, 8, 8.1 and I am sure about Windows 10. You need to install necessary device drivers in your PC as a pre-requirement. Enable USB debugging option of your mobile. If you are not familiar with how to enable USB debugging, follow this video tutorial. How To Backup Your Android Important: This is very important. You are highly recommended to backup all your existing data. You can use basic methods such as Google photos to back up all your photos and videos. Dropbox is also a good suggestion and it is capable of backup all your videos, photos, documents as well as Apps. Or either you can use one drive, Google drive or computer backup as a backup method. Choose the most appropriate backup method for you. Rootkhp Execution Methodology Step 1. Install the rootkhp in your windows PC Step 2: Enable USB debugging and connect it your PC. Step 3: Launch the rootkhp. There you will see an orange color button as root. simply click on it. Step 4: This rooting process will take few minutes to complete. It is highly advised you not to disconnect or interrupt your mobile while the rooting is ongoing. Step 5: Once you receive a message as Successful or congratulations disconnect and restart the mobile. That is all you have to do. So wish yohelpfule best. Hope my guide will helpfull for you all. |
