Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > _Games and App for Android phones
Old 03-04-2021, 04:34   #1 (permalink)
Member: 2641054
Thanks Meter: 5
Arrow [You may not know] 4 uses of flash on Smartphone
In the modern technology era, the smartphone is an indispensable object of every person in life. The phone is integrated with many different convenient features for daily life and work.
In particular, one of the simple and convenient tools is the LED flash on your phone:
1. Make night lights
Flashlight is an essential tool in current life, you will find it extremely difficult to live, work, read, search for objects in dimly lit places.
With built-in camera LED flash and providing light in just one touch. Flash makes your phone more useful and turns it into one of the lighting tools in your life.
The above highlights, LEDs also have various utility effects such as:
Flashlight lights up your night when there is a power outage.
Find your key in the dark.
Flashlight helps you to light up the road or objects that fall out at night.
Read a book at night with flash.
Take your pet for an evening walk.
Save yourself in an emergency situation with SOS light.
2. Light assist when taking pictures
The flash is an LED light usually mounted next to the camera on a phone. When taking a photo in low light with the flash on, this LED bulb will flash to add more brightness to the photo.
The light from the LED bulb is so large that the flashlight function has been programmed to flash only at the right moment when the camera is shooting, not causing annoyance to the photographer. With Flashlight - 2021 built-in Super Bright Flashlight always works with LED light to make it easy to take clear pictures in low light
3.. The distance from the flash to the illuminated subject
The distance from the flash to the subject is the maximum possible distance from the flash to the subject to ensure that the subject is well-lit. The light from the LED light cannot reach subjects located further than this distance, and the image will be underexposed as a result.
Flashlight - Super Bright Flashlight 2021 with Camera View: makes it easy for your device to shine further, in areas out of sight. With positions too high or too low, you won't have to worry about insufficient lighting. Flashlight makes it easy to fix this.
4. Flash a dance floor flash to get the air going
You're in a really exciting place, like being on the field watching a ******** match, at a birthday party with your friends or at a company party ... and want to attend In addition to the vibrant atmosphere, you can turn the flash on your smartphone into a dance floor flash to help stir up the surrounding atmosphere.
To use this, you can use an app called Flashlight - Super Bright Flashlight 2021. This is a free application that will turn the flash on / off according to the tune of a track or according to your preferences. user. You can fire up the app and bring it up to make a highlight while sitting in the ******** field or while attending a party. With many different flash modes for you to choose and use, to suit your preferences.
ON CHARGE are ways to take advantage of the flash on your Smartphone. The LED light with simple interface, elegant design, quick start helps you to use the built-in camera LED flash and provides light on the device. With just a small phone, the Flashlight helps you to light up anywhere, anytime.
Old 03-04-2021, 04:42   #2 (permalink)
Member: 2641054
Thanks Meter: 5
Lightbulb Experience to remember when going out
Currently, Pheo has become one of the hobbies of young people. The trekking helps you to have a lot of experience and gain life experience also how to handle situations on the road. But going through the evening time is also one of the difficulties and inconveniences in living. This article will share safe travel experiences so that you can prepare yourself for first-time travel.
OTHER NEEDED MATERIALS
Multi-purpose knife, lighters
Phone (choose a good wave, buffalo battery is best), bring a smartphone, remember to find some backup batteries. Especially using a flashlight at night will bring you many benefits. As the sky gets dark, having a flashlight will help solve many difficulties in the lack of light.
Camera (if you do not play photos and want to be gentle, bring some travel cameras to make it compact, of course if you have a good one, if you want a good photo and do not miss it, feel free to use it). If the lack of light restricts your photography then the flashlight app will assist you to create beautiful photos at night.
PERSONAL BELONGINGS
Personal belongings here are merely daily living items for your personal use, other items will be sorted into the appropriate categories below. Along Phai suggests you gear for a trip with a period of 3-5 days.
Pants: 1-3 pieces of which 1 is for regular use on the road, the other 1-2 pieces are only used as a backup when it is too dirty or wet (do not change to long pants every day. because if so, how much is not enough).
Thin ******** to wear in the same, this number of shirts is equivalent to the number of days you go, bringing about 3-5 pieces is okie.
Thin ******* for summer and thick ******* for winter: 2 pieces
Wind jacket: has a very good windbreak effect, if possible you should buy a jacket that is water resistant so that it will not be misted on the body. Windbreakers are often used in places where the weather is only slightly chilly.
Thick coat: In winter, the temperature in the mountains, where the lowest drops are in the evening, so need a good warm coat but still be neat, you can choose the type of feather coat. light.
Scarves: In summer, you only need a few scarves for neck wrap and head wrap will work to block the sun (not burn the neck area) and absorb sweat on the head, if the towel is long enough, only need to use 1 for all 3 missions; neck wrap, head wrap, face cover. In winter, replace the bandana with a wool scarf for better heat retention.
Cover your ears to stay warm if it's cold.
About 3-5 pairs of socks and 3-5 sets of pants / *********. The socks work to keep the soles of the feet warm, so it is very important that you just bring a little more to change in case you get wet.
*****: Use sports ***** with good grip, comfortable walking for the feet. For men, avoid using leather *****, for women, avoid using high heels and doll *****. In case of wondering between the types of ***** you just use the team *****.
Towels, brushes, toothpaste, shampoo, soap all of these should fit into a personal storage bag.
Sleeping bags for tent sleep trips. For those of you who are used to sleeping with dim light, you can use flashlight app with different light modes.
IDENTIFICATION
Driver's license: A must-have if your trip has an itinerary using a motorbike, which is also a document you can use instead of your ID card when boarding the plane.
Vehicle registration, vehicle insurance, road toll payment certificate: Essentials to avoid trouble with traffic police while on the road
Passport + ID card: When entering the border area, as a rule you will have to present identification to the border post that manages the area, so you should bring your ID card, in some cases If you want to go to the other side of the tourist border, you need to have an additional passport.
Page generated in 0.17043 seconds with 8 queries
