BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
02-17-2010, 07:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 528831 Status: Offline Thanks Meter: 18 | black berry 8300 sorry,outgoing calls are not allowed i have unlocked one blackberry 8300. i can received incoming call but no outgoing call getting this error sorry,outgoing call are not allowed thanks in advance |
The Following User Says Thank You to dheeraj_b For This Useful Post: |
02-17-2010, 09:41 | #4 (permalink) |
Freak Poster Join Date: Nov 2009 Location: RU - Saint-Petersburg
Member: 1170297 Status: Offline Sonork: \m/(-_o)\m/ Thanks Meter: 36 | 10 times type password for device wrong - it will be wiped automatically... (back up your data if it necessary!!!) afte that - read this http://forum.gsmhosting.com/vbb/show...86&postcount=2 |
02-17-2010, 10:33 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | remove IT policy. follow this http://forum.gsmhosting.com/vbb/show...86&postcount=2 |
02-17-2010, 10:36 | #8 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: Native
Member: 368987 Status: Offline Thanks Meter: 26 | Quote:
remove it by downloading the policy bin and follow this instruction Procedure Step 1 : Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. Step 2 : Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 : Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 : Close the Desktop Manager if it is open. Step 5 : From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 : Open the Desktop Manager. Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. Things should be back to ok | |
02-17-2010, 11:01 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Easy way to remove IT Policy 1, Download and install DM 5, 2, Download the file policy.bin and save it in directory (C:\Program Files\Research In Motion\BlackBerry) 3, Wipe ur BB, creating a backup if necessary. Select Options/Security/Wipe Or Options/Security Options/General Settings/Wipe 4, Go Start Menu select Run Then type 'regedit' and go HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin 5. Open the Desktop Manager, Connect the Device.Wait for Verification Done ! |
The Following 14 Users Say Thank You to delower10 For This Useful Post: |
06-08-2010, 04:12 | #11 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | hi all pls i am having problem with the last step i dont know what the verification means cos after doing all other steps and plug the blackberry to the system it still displays device password required and i have to enter it ten times before the blackberry can reset pls guide me i need to remove it policy from my 8310 and after flashing with destop manager it still request for password on the screen does the verification mean re flashing it with the desktop manager? |
06-08-2010, 06:31 | #12 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: BanglaDesh
Member: 597570 Status: Offline Sonork: 100.1590733 Thanks Meter: 159 | Quote:
u can do all step after when u open DM than plug the device with system its auto run verification wait for until complete. good luck | |
06-09-2010, 02:18 | #13 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | hi all pls i am having problem with the last step i dont know what the verification means cos after doing all other steps and plug the blackberry to the system it still displays device password required and i have to enter it ten times before the blackberry can reset pls guide me i need to remove it policy from my 8310 and after flashing with destop manager it still request for password on the screen does the verification mean re flashing it with the desktop manager? pls i need a better explanation when i plug it to the system after doing steps 1 to 6 it request for password and no verification for any thing occurs |
06-09-2010, 04:32 | #14 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | after several trial i did it at last what i did differently was that instead of flashing with system i did wipe hand held device on the blackberry then installed on a new system desktop manager 5 and 8310 firmware also did all procedures from 1 to 6 so when i plugged the bb 8310 it asked for backup since it was the first time off plugging a bb device i said yes so after the back up it did the so called "verification" which was just a short process in less than 2 mins (not a full restoring or flashing process)and displayed on the phone that the it policy was blank i.e removed thanks to all |
06-09-2010, 05:40 | #15 (permalink) |
Member: 597570 Status: Offline Sonork: 100.1590733 Thanks Meter: 159 | hello post read carefully nd Understand ok follow instruction again easy way Remove IT Policy From BlackBerry |
BLACK BERRY 8300 Problem??? | Bismillah_mob | Nokia Hardware & Hardware Repair | 1 | 08-29-2009 15:52 |
Black berry 8300 v4.5.0.37 this it doesn't exist in the support sfi | Paul Guaņuna | FuriousGold | 1 | 02-11-2009 13:25 |
black berry 8300 how long? | pasakalye | A1-Services.org | 0 | 09-29-2008 03:45 |
nokia 6600 WHITE LIGHT. INCOMMING AND OUTGOING CALLS ARE OK. | shahi | Nokia Hardware & Hardware Repair | 3 | 12-17-2007 07:30 |
how to unlock black berry 8300 | east asia link | BlackBerry (RIM) | 1 | 10-11-2007 02:40 |
