BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
02-25-2010, 15:40 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: india punjab
Member: 507832 Status: Offline Thanks Meter: 78 | black blackberry 9000 problem http://i50.tinypic.com/2w593rm.jpg recot phone same problm |
02-25-2010, 15:54 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | @thethi your device password protected, Wipe your device using JL_Cmder then make update using loader.exe make sure u have battery full charge. BR Delower |
02-27-2010, 10:28 | #5 (permalink) |
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Forget the JL Cmder and do this, Run Loader from c:\program files\common files\research in motion\apploader Enter 10 times wrong pass, it will be wipe automatically, then close loader Run MFI and make erase after complete run loader again and update ur device BR Delower |
02-27-2010, 11:37 | #6 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: USA N China
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | Quote:
03-02-2010, 12:19 | #11 (permalink) |
Member: 507832 Status: Offline Thanks Meter: 78 | hi sir ji full eres bb loder http://i48.tinypic.com/2gxdweo.jpg |
03-02-2010, 12:37 | #12 (permalink) |
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Unable to connect to the BlackBerry smartphone during a multistage loading operation thethi Follow this, Unable to connect to the BlackBerry smartphone during a multistage loading operation Problem The following error appears when Application Loader is used: Unable to complete the loading operation. Unable to connect to the handheld during a multistage loading operation. -------------------------------------------------------------------------------- Cause There are multiple causes for this issue. There is insufficient power for the loading operation to complete on the BlackBerry smartphone. The connection between the USB port of the BlackBerry smartphone and the computer's USB port is unsustainable. The USB drivers failed to initialize during BlackBerry smartphone initialization. -------------------------------------------------------------------------------- Resolution Complete the following tasks: Verify that the battery is inserted in the BlackBerry smartphone. Verify that the battery is not faulty. Turn off the Power Management option for the USB root hubs on the computer. For instructions, see the Additional Information section. If a laptop computer is being used, make sure the computer is not connected to a docking station. Make sure the BlackBerry smartphone is connected directly to the computer and not to a USB hub. Disconnect all other USB devices (for instance, cameras) from the computer. Connect the BlackBerry smartphone to another USB port on the computer. Turn off antivirus or firewall programs that are running on the computer. Turn the programs on again once a connection to the BlackBerry smartphone is established. -------------------------------------------------------------------------------- Additional Information To disable the Power Management option for the USB root hubs on the computer, complete the following steps: Open the Control Panel by clicking Start > Settings > Control Panel. In the Control Panel, double-click System. Select the Hardware tab and click Device Manager. In the Device Manager, expand Universal Serial Bus controllers. Right-click USB Root Hub and select Properties. Select the Power Management tab and clear the Allow the computer to turn off this device to save power check box. Repeat steps five and six for other entries named USB Root Hub. PS: Its from blackberry support hope u will understand it. Best Regards Delower |
The Following 7 Users Say Thank You to delower10 For This Useful Post: |
06-05-2010, 19:27 | #13 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: Uzbekistan
Member: 726032 Status: Offline Sonork: ....Ssstt.... Thanks Meter: 15 | Quote:
Problem solved with rehoot Emif... cause bsi line short.. br, javaz | |
Blackberry 9000 problem | 55533faisal | BlackBerry (RIM) | 3 | 03-20-2010 15:06 |
blackberry 9000 problem | ghost_team | BlackBerry (RIM) | 1 | 11-03-2009 09:35 |
Color Plate Housing with LOGO for Blackberry 9000 Phone - Black | IPMART | ipmart WebShop | 0 | 04-02-2009 06:30 |
Refurbished BlackBerry 9000 - Black (Unlocked) | IPMART | ipmart WebShop | 0 | 03-12-2009 11:10 |
Blackberry 9000 problem... | boengo | BlackBerry (RIM) | 1 | 01-18-2009 01:20 |
