BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-12-2009, 10:07 | #1 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1048014 Status: Offline Thanks Meter: 0 | BlackBerry 8700 - Call Failed error.. help needed But when dail any number immedialty its showing call failed error. Pleas help on this.. I have done this setting also still same.. 24. how to solve Authorization Failure?? Here is the solution: Go to Phone Options Select General Options Select Restrict My Identityt - NO Select Show "My Number" - YES You are all set. No more Authorization Failure sending / receiving calls and messages. |
06-12-2009, 11:09 | #4 (permalink) |
Member: 1048014 Status: Offline Thanks Meter: 0 | any body needs to check their IMEI no is blocked or not.. Pls use this link http://www.amta.org.au/default.asp?Page=405 thanks |
BlackBerry 8700 - Call Failed error. | mostwantedkiss | BlackBerry (RIM) | 5 | 07-14-2011 10:22 |
Blackberry 8310 Call Failed | Zarubica | BlackBerry (RIM) | 4 | 01-12-2010 12:44 |
Blackberry 8100 call fail | Lutfur | BlackBerry (RIM) | 0 | 02-23-2009 07:38 |
BlackBerry 8700 Call Barring Password? | dmitrik | FuriousGold | 5 | 01-20-2009 12:51 |
Call failed motorola E398 need help | patoandres007 | Motorola Hardware Repair | 1 | 04-22-2008 04:04 |
