BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
12-04-2008, 19:26 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | You guyess forget to read blackberry faq ? Read point no 21. how to solve if i get this massage (sorry only emergency call are allowed) in call ? from blackberry faq |
The Following User Says Thank You to ::.::RAMJAN::.:: For This Useful Post: |
12-04-2008, 19:42 | #8 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | RAMJAN i figured this problem comes when all attempt are finished and is at 0 .,.. Network lock is still enabled if u check after doing the unlocking with this software ..everything goes well and after you finish flashing the network is up and running but you cant make calls .. emergency calls only ,, I rechecked with the mepd code and it still says network lock enabled and when type MEP2 all attempts are used 0 ... So i dont think the Policy thing shud work but i will try ,, please if you have solution for this problem let me know .. i have 8707 and it has the same problem and at the moment cannot be solved unfortunately thanks mike |
12-04-2008, 22:03 | #10 (permalink) | |
Freak Poster Join Date: May 2008
Member: 780271 Status: Offline Thanks Meter: 1 | Quote:
look here: http://forum.gsmhosting.com/vbb/show...86&postcount=2 | |
7230 after unlock emergency calls only (Answered) | gsm_ | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 2 | 03-12-2010 14:40 |
Blackberry 8800 Emergency call only | luckey | BlackBerry (RIM) | 1 | 02-28-2009 21:48 |
blackberry emergency calls only | timihills | BlackBerry (RIM) | 6 | 06-18-2008 12:20 |
emergency calls only after unlock on A920 | alru111 | Smart-Clip | 3 | 08-09-2005 08:12 |
