BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
10-23-2009, 22:35 | #37 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1148054 Status: Offline Thanks Meter: 0 | Fail when using MML I am unlocking BB8700. Though enabling "full arase" and "auto start", it failed after a few miunutes in "CFP Nuke, taht operation time out" (The database:Offline and Logging: Off". later following your instruction to run again by "clear MEP" it failed also said " deature not supported by firmware version: ... cannot set MEP data, cannot load MEP file". I am using BB desktop 4.7 and OS 4.5. Please help and instruct. Thanks. |
11-04-2009, 21:29 | #43 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1153812 Status: Offline Thanks Meter: 1 | After Using MFI MUltiLOader i get the Pass msg i disconnected the bb ..closed the MFI and opened device manager .. step one loads everything ok .. it fails on Step 2 Reconnecting to JVM ... what kan be the problem tried it several times |
11-08-2009, 12:38 | #44 (permalink) |
Junior Member Join Date: May 2009
Member: 1041179 Status: Offline Thanks Meter: 27 | The problem can be (in many cases) your operating system (read: Vista or Win7). Read carefully my "step-by-step" Requirements! Try not to rush the procedure and skip any step. If you have Vista, try installing VMware and a virtual XP OS (if your processor enables you to do that....read: you need to have VT (Virtualization Technology) enabled in your BOOT MENU). Regards, Cimo. PS: Before trying a virtual XP, try running all programs (read: MFI, Desktop Manager...) as Administrator ("Run as Administrator" when Right-click your mouse). |
Guide: How to Activate SETOOL Step by Step | shahzaadbutt | SETool2 | 66 | 06-15-2023 11:12 |
Blackberry Step by step procedure for unlocking using MX-KEY | tims | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 0 | 02-05-2010 16:16 |
Step by step unlock procedure for V3? | Jeranamo | Motorola P2k | 3 | 07-17-2007 03:11 |
Is there a step by step procedure for an L7 dead after Unlock ? | N/East Unlocker | Ultima Box Light | 6 | 01-25-2007 13:48 |
step by step procedure unlocking v804ss | kwayzi | QUALCOMM Models (3G) | 3 | 10-05-2006 14:24 |
