BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
05-21-2009, 07:20 | #1 (permalink) |
Insane Poster Join Date: Apr 2003 Location: Uk
Member: 26584 Status: Offline Sonork: 100.1577865 Thanks Meter: 10 | Blackberry 9500 camera Problem could not start the camera. close other applications and try opening the camera again. Anybody help Thanks |
05-24-2009, 08:12 | #3 (permalink) | ||
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Quote:
re flash fone solved ur problem same problem my 8300 after flash sovled my problem this is security problem so flash new firmware or same firmware solved ur problem thanxs | ||
05-24-2009, 08:42 | #8 (permalink) |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | okz read this maybe solved ur problem http://www.blackberryforums.com/gene...era-error.html http://supportforums.blackberry.com/...id=70734#M4853 http://forums.crackberry.com/showthread.php?t=225576 check n reply me |
05-24-2009, 08:42 | #9 (permalink) |
Member: 26584 Status: Offline Sonork: 100.1577865 Thanks Meter: 10 | Brother i flash phn with new firmware but same, I read on other forums pull battery out when set on that ll fix that problem but no luck. Some says open the back and with a small screwdriver or just use the back case itself pressed around the outer plastic ring of the camera that ll fix but no luck Plz help |
12-25-2010, 19:29 | #13 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | THIS 100% HARDWARE PROBLEM . HERE IS LINK I HOPE U R PROBLEM SOLVE YouTube - How to fix Blackberry Camera Error |
The Following User Says Thank You to sajidashraf For This Useful Post: |
04-22-2011, 23:35 | #15 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Poland
Member: 360641 Status: Offline Thanks Meter: 38 | solution camera problem Quote:
Real work solution . My camera back to live. Thank | |
BB 9500 camera problem | tr3pplea | BlackBerry (RIM) | 2 | 11-07-2010 14:17 |
Blackberry 8320 camera problem | GuilleC_PMA | BlackBerry (RIM) | 2 | 03-27-2010 07:18 |
Blackberry 9500 Unlock Problem | suburvio | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 3 | 02-22-2010 23:40 |
Blackberry 9500 key problem | mgtsales | BlackBerry (RIM) | 1 | 12-30-2009 20:04 |
blackberry 9500 power problem | mobileunlockers | BlackBerry (RIM) | 4 | 11-20-2009 10:56 |
