BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
09-12-2008, 23:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: USA N China
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | Blackberry Code error (Wrong code) Solution. You got message "code error" when try to unlock a blackberry, Dont worry here is the solution. When you get code error specially with 8 digit unlock code, follow the instructions below to fix this and able to unlock blackberry phones successfully. Always put sim (any operator sim) inside while entering unlock code, some time code not accept without sim card also. Download and Extract the file and save it to your personal computer. Connect the device to the personal computer using Blackberry Desktop Manager. Double-click the downloaded file SIM_Unlock_Tool_USB_BlackBerry_Gsmfather_server. If prompted, enter your device password. The unlock tool runs, and the device resets when complete. Proceed with the SIM unlock instructions provided by Server. SIM_Unlock_Tool_USB_BlackBerry_Gsmfather_server.zi p for Blackberry 8xxx and 7xxx series. SIM_Unlock_Tool_serial_BlackBerry_Gsmfather_server .zip for 6710 Regards Raees |
The Following 26 Users Say Thank You to :::GsmFather::: For This Useful Post: |
09-15-2008, 20:51 | #3 (permalink) |
No Life Poster Join Date: Mar 2003 Location: NCK, Logs, Server
Member: 23684 Status: Offline Sonork: 1582723 Thanks Meter: 684 | For what those tool's needed ? Reset counter of tries, or what ? WBR ! |
The Following User Says Thank You to moldovan For This Useful Post: |
09-15-2008, 22:11 | #4 (permalink) |
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | For resetting counter work in 7xxx series and i am not sure it will work for 8xxx series or not. btw this tool is to fix when you have correct code and you enter the code and phone shows "wrong code" |
09-24-2008, 00:00 | #9 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 754572 Status: Offline Thanks Meter: 9 | Hi i have a Blackberry 8800 and I have IT policy enabled on it, Whenever i connect it to computer it,windows(Xp,Vista both) picks it up as Blackberry SD device(MMC is out),so i cant use it with BBdesktop manager.. The reason why i want to disable IT policy is that i need to disable firewall on it and i need to disable security on it..... Any solution plz Help BR |
09-24-2008, 07:49 | #10 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | Quote:
http:///vbb/showpo...4&postcount=55 | |
04-25-2009, 05:10 | #13 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Inside Blackberry
Member: 288462 Status: Offline Thanks Meter: 87 | I got 3pcs of Bold 9000 as well from customer. Phone originally is from Orange UK but he flash it to O2. All 3 pcs have code error while entering them. Can this program help? Cos when I launch it display code error 10 then it exits. Regards GFI |
10-01-2009, 15:37 | #14 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 4270 Status: Offline Thanks Meter: 13 | Error Code : 10 Hi i have an 8900. I got the code from GSMfather, the problem i am having is : Wrong Code the code i received is an 8 digit code. so i decided to try this tool to make it work, but unfortunately i get error code : 10 when i use this tool. please help. best regards reo |
Blackberry Code Error (Wrong code) Solution. | :::GsmFather::: | Gsmfather The Wholesale Unlocking Database | 34 | 02-16-2014 09:54 |
Vodafone UK 5310 code error (Wrong code) | unlockcare.us | Gsmfather The Wholesale Unlocking Database | 8 | 12-31-2008 19:39 |
blackberry codes error!!!! kindly check | ryumahon | Gsmfather The Wholesale Unlocking Database | 5 | 10-02-2008 06:13 |
7390 blackberry code error... | ryumahon | Gsmfather The Wholesale Unlocking Database | 3 | 06-17-2008 15:22 |
blackberry code error | gena | UnlockBase | 1 | 04-10-2008 16:43 |
