FAQ}-Blackberry z10 {Hang / Block / 10 Left Password / Red Light } ETC HI Guys, I seen in forum always user posting to BB Section about z10 hang on logo , Red light , blocked password Etc problem . So let's me explain here about these problem and solution . Kindly next time before post fellow my solution Update With BB Link/Autoloader : You can update your phone with Autoloader Remember you must use your same STL OS (EXAMPLE - STL100-1 ETC). STL version have in your phone back side . So you can download correct OS for your Phone . Also you can update your phone with BB Link Its Online updater , 1st time take long time for Os downloading 2nd time no need long time , Cases you have download already ! Remember Some time unable to detect on BB Link , This case Simple wipe your Phone With CFP ( I already share in below ) Then connect to BB Link ! Hang On Logo / Red light :
Password Block/10 Left :
Impotent note :
http://forum.gsmhosting.com/vbb/f489...-done-2000413/ __________________ Use the Forum according to Rules...! Each section has Rules to follow Cordially, AzimBahar/ParvezAhmed |
pls ignore the first post.its a mistake. I mean how do you solve the problem of Q10 red blinking with blocked password. The password remains 10 attempt even if you enter correct or wrong password? |
Br;) AzimBahar/ParvezAhmed.NET |
Blackberry z10 10 Attempt Left Solution / Password block 10 Attempt Blackberry z10 10 Attempt Left Solution / Password block 10 Attempt : Read Details - http://forum.gsmhosting.com/vbb/f489.../#post10870895 Look on the screenshot Its always in 10 Left with Autoloarder , Here show 6 LEFT cases 1st i did try with cfp tools 4 time :D https://fbcdn-sphotos-f-a.akamaihd.n...47b3f9cefb7cd7 lets see here , Its will work with CFP tools https://scontent-kul.xx.fbcdn.net/hp...2a&oe=5548974D After 10 try entry , you need wait 10 to 15 Min :D Br;) AzimBahar/ParvezAhmed |
If hardware, What is the likely Solution |
what's version about CFP? :) |
Use it Only : CFP For Blackberry Z10 By AzimBahar Br;) AzimBahar/ParvezAdmed |
pls can we get link for CFP For Blackberry Q10 and Q5 ? |
Blackberry Z10 Password Block/10 Left bro can i remove password without user data delete this procedure |
Only Via Cellebrite Can Read User Code Without Losing Personal Data |
Does this software work for Z-30 ? Thank you. |
