Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 08-16-2014, 10:45   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Fix a Bricked BlackBerry PlayBook Tablet & Updating
Unbrick yur playbook using AutoLoader
Playbook AutoLoader
* Download Below given Autoloader OS
* Run the Autoloader.exe
* Connect yur playbook to yur pc
* Press power button for 10 to 12 sec nd release
* If yur Playbook detected by pc it vil start the process
PlayBook OS 2.1.0.1753 Download
Guide to update via pc using desktop manager
Download Latest Desktop manger here
Update using Desktop Manager
* Connect the BlackBerry PlayBook to a computer running BlackBerry Desktop Software
On the home screen of the BlackBerry Desktop Software, click Update.
* To download an update, click Get Update.
* To view other available versions of the BlackBerry® PlayBook OS software, click View other versions. If applicable, select another version. Click Install.
* After the BlackBerry PlayBook OS update is complete, disconnect the BlackBerry PlayBook from the computer.
Unbricking Tutorial
Open up BlackBerry Desktop Manager on your Computer
and plug in the bricked PlayBook using the USB Cable.
It will bring up a window that says “BlackBerry Desktop
Software cannot communicate with the connected device.”
and present you with options to “Retry“, “Update“or “Cancel“
If it doesnt bring up this window when you plugged in
your PlayBook via USB, consider unplugging and reconnecting,
possibly to a different USB port, until you hear that familiar
sound your computer uses to indicate a newly connected device.
On the popup window, click “Retry” first, to allow it to attempt
to reboot your PlayBook for you. Be patient as it will take a while.
If after 10 mins and your PlayBook still won’t boot, unplug and reconnect
it again until it opens up the same window described and shown in Step 3.
When presented with the choices to Retry, Update, Cancel, click on “Update” this time.
BlackBerry Desktop Software will open up a new popup window “Confirm device repair“,
and forewarn you of what you’re about to do.
Click on “Repair”. This will then open up a popup window that says “Checking for
BlackBerry Tablet OS Updates“. Duration will depend on computer resources and internet
connection, but it should take only about a minute.
n some cases, you may be prompted/asked to “Reset your device.”
before BlackBerry Desktop Software can proceed in checking for the OS Updates.
Just follow the instruction provided [as shown in the picture below].
Once BlackBerry Desktop Software completes the OS Update check,
it will report the latest officially available OS for your PlayBook,
and prompt you to either “Get update” or “Update later“.
Click on “Get update.” This will bring up another
confirmation popup window forewarning you of the duration,
and giving you the option to “Install update” or “Cancel“.
Click on “Install update” if you are totally sure.
BlackBerry Desktop Software will begin the download process,
which can take up to hours depending on your internet connection speed
Once it’s done downloading, BlackBerry Desktop Software will
then automatically extract and install the OS onto your PlayBook,
and then connect to the PlayBook to reboot it
If everything proceeded well, your PlayBook should boot up
The Following 3 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-25-2014, 08:38   #2 (permalink)
mike_shinoda's Avatar
Member: 2136780
Thanks Meter: 68
Playbook AutoLoader
PlayBook OS 2.1.0.1917 Download
Unbricking Tutorial
please check link download 2.1.0.1917
Old 11-25-2014, 08:53   #3 (permalink)
I_PHONE's Avatar
Member: 1579234
Sonork: Not user
Thanks Meter: 342
plz Help me
http://forum.gsmhosting.com/vbb/f489...rgent-1864655/
Old 11-26-2014, 11:49   #4 (permalink)
Member: 2300008
links are not working of files, can you please update it?
Old 11-26-2014, 19:39   #5 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Autoloader link has been updated
james
Sent from my SM-G900F using Tapatalk
Old 11-27-2014, 16:52   #6 (permalink)
Member: 2136780
Thanks Meter: 68
last ver 2.1.0.1917
http://forum.gsmhosting.com/vbb/10698572-post79.html
Old 11-27-2014, 17:25   #7 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Originally Posted by mike_shinoda View Post
its not autoloader exe
james
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 12-03-2014, 05:33   #8 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 233
Playbook AutoLoader
Unbricking Tutorial
hello bro i tried both method what you provide but no luck for me. every thing is going well when update processing but playbook not run. when updating only green light. when i plug charger its just show red light and blink after 30 second then again red light.
do you have any salutation for this palybook.
thanks..
Old 05-03-2015, 07:42   #9 (permalink)
Member: 1271198
Sonork: cazwj
Hell bro my playbook no thal languages ,need uodate thal ,but i found't rom,plz help me,thank you so much
Old 01-10-2016, 05:20   #10 (permalink)
Member: 661214
Thanks Meter: 4
hi jamesjerss sir
plz solve my problem how to remove/bypass blackberry id in playbook
thankq....
Old 03-27-2016, 05:31   #11 (permalink)
Member: 650289
Thanks Meter: 56
Originally Posted by venu_151415 View Post
hi jamesjerss sir
thankq....
Need Autoloader for blackberry playbook 32gb and my problem was same remove/bypass blackberry
Old 04-25-2016, 08:20   #12 (permalink)
Member: 795785
Sonork: 100.1601618
Thanks Meter: 4
playbook dead
hi to all i have blackberry playbook dead after power just 5 times green light blinking please help me about that
Old 09-05-2016, 20:39   #13 (permalink)
Member: 1541217
Thanks Meter: 32
PB_2.1.0.1753_RADIO_2.1.0.1283 - Download - 4shared
The Following User Says Thank You to jony25 For This Useful Post:
Old 09-23-2016, 10:50   #14 (permalink)
Member: 709604
Thanks Meter: 173
PB_2.1.0.1753_RADIO_2.1.0.1283 - Download - 4shared i will try
Old 06-25-2020, 21:22   #15 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
Hello
Please i need rapido instaler PlayBook OS 2.1.0.1917
Thanks
mfeliu07
Page generated in 0.26448 seconds with 8 queries
