BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
03-05-2011, 09:21 | #571 (permalink) |
Junior Member Join Date: Mar 2011 Location: Campeche, Mexico
Member: 1529743 Status: Offline Thanks Meter: 1 | it only detects 2G networks, and no 3G network, and when it registers over the 2G network, the phone goes into roaming, and i get EDGE but cant get data transfer, voice has no troubles. when checking over advncd optins > sim card and tying MEPD, it shows all the options as DISABLED but the NETWORK sais INACTIVE, before using the code i got from here it said ACTIVE, the i used the code and went into INACTIVE, i only tried the code 1 time and got CODE ACCEPTED, te counter had (10 tries left), so im 100% sure i didn't screw-up when unblocking. please help me!!! |
The Following User Says Thank You to JaGuAr81 For This Useful Post: |
03-10-2011, 20:38 | #572 (permalink) |
Freak Poster Join Date: Oct 2006 Location: UK
Member: 380236 Status: Offline Thanks Meter: 21 | hi all, i have an 8520 that had software problems, wiped handset using JLcommander and reloaded using no jvm option via application loader. anyway handset seemed to go through loading but it hangs at 3qtrs theway along the boot sequence, tried pulling the battery over night and reboot again but no luck. Any ideas peeps Cheers |
The Following User Says Thank You to mobileman999 For This Useful Post: |
03-10-2011, 23:09 | #574 (permalink) |
Member: 1529098 Status: Offline Thanks Meter: 2 | Hi everybody: Does anybody can help me??? I unlocked my bb 9530, with the mep2 of some of the guys here gave me. I can call and received calls, but in the LCD it shows it requieres activation, is there something I can do??? Please give me a reply. Thanks in advanced!!! |
The Following User Says Thank You to mptene For This Useful Post: |
03-17-2011, 17:13 | #575 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1183648 Status: Offline Thanks Meter: 1 | I want to flash my blackberry Bold 9700 with a no branded flash file! Can you indicate me how i do to get this file? Thanks in advance ! |
The Following User Says Thank You to Edoutechno For This Useful Post: |
03-27-2011, 02:42 | #578 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 717200 Status: Offline Thanks Meter: 14 | thats sounds sticky becaused if you chane the mic it should work perfectly question??? the mic u placed in it, was it a working mic?????????? anyways if its still now working you have two options 1. to get an ear phone with the mic on it 2. get a new or different circuit board.... |
The Following User Says Thank You to MICOUS For This Useful Post: |
03-27-2011, 02:48 | #579 (permalink) | |
Member: 717200 Status: Offline Thanks Meter: 14 | Quote:
note::: wen it speaks of a particular flash file (eg) rogers, at&t, it dosent matter cuz it cant change what is in the phone already | |
03-27-2011, 02:51 | #580 (permalink) | |
solution.... try and flash it, i have never tried it before so i cant be positive it will work but its worth a try | |
03-27-2011, 03:57 | #581 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,058 | If you Search on Google you will find lots of link "how to Read MER withou cable"... |
The Following User Says Thank You to xerraco For This Useful Post: |
04-07-2011, 15:59 | #583 (permalink) |
Member: 380236 Status: Offline Thanks Meter: 21 | Hi, i have a blackberry 8110 that failed during software update, it was working fine before that. jl commander wont allow to wipe as it wont connect, neither will javaloader -usb wipe. the handset is detected using apploader and handset pin is showing against usb it selects the software and trys to install but will not get past the device connecting stage. i have tried with ands without battery and wait for device installisting to install battery. Can anyone solve this for me please ? |
04-10-2011, 09:43 | #584 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1553199 Status: Offline Sonork: [email protected] Thanks Meter: 1 | I have a Blackberry 8520 and whenever I make a call the other person seems to complain about my voice not reaching them ... I mean the mic volume is tooooo low and hardly heard at the other end. Please advise...thanks in advance |
The Following User Says Thank You to haris271 For This Useful Post: |
04-11-2011, 06:41 | #585 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Azerbaijan Age: 54
Member: 897164 Status: Offline Thanks Meter: 101 | 2 haris271 Please check mic. hole . There is protecter and may be was fouled Sorry for my English |
The Following User Says Thank You to DemnZ For This Useful Post: |
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 4 | 03-23-2011 08:03 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | Mohsin-* | FuriousGold | 0 | 11-10-2008 16:00 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 0 | 08-02-2007 20:08 |
