BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-25-2009, 12:15 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: Greenhills,Philippines
Member: 771856 Status: Offline Sonork: 100.1582636 Thanks Meter: 793 | REMOVE YOUR IT POLICY 8xxx Series IT Policy Simple Procedure To Remove If you have any 8xxx device the best method for removing IT policy is to update it to OS 4.3 or higher (if possible) and you can use JL_Cmder's "resettofactory" command to remove ALL IT policy, Firewall restrictions and Application Permission settings. After you've upgraded to OS 4.3 or higher, simply backup the device using Desktop Manager, close Desktop Manager, then run JL_Cmder and execute the "resettofactory" command. The device will do a security wipe of the device; (meaning wipe your data but leave the OS, DO NOT use the "Wipe" command in JL_Cmder) then reboot leaving the OS, 3rd party apps but no data AND, best of all, NO IT policy whatsoever. When you're done, simply restore your backup and you're good to go with no policy or locked firewall. You can downgrade back to the old OS if you desire, too. FILE TO USE JL_CMDER Click Me To Download Instruction How To Use : Install JL_Cmder & Run the file locate at C:Program Files/JL-Cmder Press Any Key To Continue Press Y In keyboard Then Type The Password Press 5 In Keyboard And Follow The Instruction Show In JL_Cmder Wait the JL_cmder Done In Process Then Remove The Cable Insert Battery After Wipe Already Done. If the JL Cmder will not connected SOLUTION Code: * Note: If you are connecting via a USB HUB then these instructions may not work. Try connecting via USB on a PC that is not using a HUB Pre-Install Tasks 1. Disconnect the device from the PC 2. Download and install Desktop Manager and the Handheld OS to the PC (if they have not already been installed): |
sos call only bf3, pls help. | ossada | BF, BG, TH, BHx Series | 5 | 07-28-2003 07:25 |
Please help be5 121 01 sos call only | Visar Mato | Alcatel & TCL Old Models | 0 | 11-24-2002 08:14 |
BF3:Warning!SOS calls only!What to do? | Bogi | BF, BG, TH, BHx Series | 3 | 06-18-2002 02:39 |
OTE DB - SOS calls only | farsands | Alcatel & TCL Old Models | 12 | 05-10-2002 20:13 |
T20 SOS call only | loopkiller | Old Ericsson Phones & Sony Phones | 0 | 11-01-2001 19:40 |
