BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
05-02-2009, 19:20 | #2 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Jakarta,DKI,indonesia
Member: 3179 Status: Offline Thanks Meter: 142 | look thisb soft part for 2 different bold QWERTY HWV-13901-005-3 SVP-17969-001_1 SVP-17970-001_1 ASY-12591-065 MEP-04598-005 CFG-10996-040 SFI-17798-059 APP-22520-001 PRD-12528-103 SWM-22444-001 VSM-22164-001 QWERTZ HWV-13901-005-3 SVP-17969-001_1 SVP-17970-001_1 ASY-12591-052 MEP-04103-001 CFG-10696-061 SFI-17798-068 APP-22116-005 PRD-12528-005 SWM-22257-003 VSM-06710-004 |
The Following 3 Users Say Thank You to mardi For This Useful Post: |
05-03-2009, 09:07 | #3 (permalink) |
Member: 3179 Status: Offline Thanks Meter: 142 | QWRTZ Connecting to Bootrom: Connected [ Uploading RAM Image 0x8002B6B4 ] [############## 100 ##############] Bootrom Version: 5.4.0.18 Hardware ID: 0x84000E07 RIM BlackBerry Device Supported Bands: 0x000F Metrics Version: 6.0 Build Date: May 28 2008 Build Time: 15:55:26 Build User: schen Security: Enabled Drivers: 0x00000004 LDR Blocks: 0x5C01E500 Bootrom Size: 0x00020000 External MCT/HWV: Enabled HWV: Board Revision 0001 - 0x10 CPU Version 0002 - 0xE7 SW Compatibility 0003 - 0x02 Board Sub-revision 0004 - 0x0F Power Mgt Hardware 0007 - 0x25 Mem Config Table (ver 1.14): Flash Chip: blocks 0-996, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-979 OS NV: blocks 980-996, total 17 CRC: 0x98588CE1 Flash: Number of chips: 1 Flash ID: NAND blocks 0-996 Total Size: 124.6 MB Memory Map: NAND Blocks: 997 * 128 Kb RAM Base: 0x80000000 IRAM Base: 0x5C000000 OS Range: 2 - 137 File System: Memory Map: 138 - 979 Sectors: 842 Branding: VendorID: 154 OS Version: 4.0.0.206 Hardware ID: 0x84000E07 RIM BlackBerry Device Supported Bands: 0x0000FFFF Metrics Version: 3.16 FS Code Version: 10.0.0.0 FAT Code Version: 2.15 Package Version: "4.0.0.206" Build Date: Feb 27 2009 Build Time: 17:39:51 Build User: absadmin SV Number: 0 OS Address: 0x80000000-0x810F7393 App Start: 0x8063A038 Companion Binary: 0.0.0.0 RAM usage: 0x8703FFFC-0x877AFFFC IRAM End: 0xD0F90068 DSP ROM2 Address: *not present* OS Extended Addr: 0x80C78BE4 LDR Blocks: 0x80D6044C API Checksum: 0x00000000 JumpTable (<3): 0x80000300 JumpTable (>2): 0x80001E48 Radio Code: Janus radio code linked OS API Version: 109.26 STP Protocol Ver: 5.133.4 (release OS) HWV: Board Revision 0001 - [0x0C - 0xFF], 0x01 Board Sub-revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0xE7 - 0xE7], 0x01 CPU Version 0002 - [0xEA - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x02], 0x01 Power Mgt Hardware 0007 - [0x23 - 0xFF], 0x01 Version Table: OS API Version: 109.26 STP protocol version: 5.133.4 BlockFS API Version: 10.0.0.0 USB driver version: 02.01 FAT FS Version: 2.15 Block map version: 2.3 WLAN radio version: 2.4.0.83 Kernel Version: 1.10.0.252 Hardware ID: 0x84000E07 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Feb 27 2009 Build Time: 16:06:11 Build User: SCM App: Version: 4.6.0.247 Metrics Version: 1.6 Build Date: Feb 27 2009 Build Time: 18:44:14 Build User: RIM Memory Map: 0x8063A038-0x80C78BE3 App c_main: 0x807AE6C4 API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 AppFSVersion: 3.0.0.0 AppFSSize: 0x3D00000 OS API Version: 109.26 RAM Map: 0x8703FFDC-0x87040000 IRAM Map: Unused App Type: JVM Done. |
The Following User Says Thank You to mardi For This Useful Post: |
05-03-2009, 09:09 | #4 (permalink) |
Member: 3179 Status: Offline Thanks Meter: 142 | QWERTY Connecting to Bootrom: Connected [ Uploading RAM Image 0x8002B6B4 ] [############## 100 ##############] Bootrom Version: 5.4.0.21 Hardware ID: 0x84000E07 RIM BlackBerry Device Supported Bands: 0x000F Metrics Version: 6.1 Build Date: Sep 15 2008 Build Time: 15:57:12 Build User: rdagg Security: Enabled Drivers: 0x00000004 LDR Blocks: 0x5C01E5B8 Bootrom Size: 0x00020000 External MCT/HWV: Enabled HWV: Board Revision 0001 - 0x10 CPU Version 0002 - 0xE7 SW Compatibility 0003 - 0x02 Board Sub-revision 0004 - 0x0F Power Mgt Hardware 0007 - 0x25 Mem Config Table (ver 1.14): Flash Chip: blocks 0-996, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-979 OS NV: blocks 980-996, total 17 CRC: 0x98588CE1 Flash: Number of chips: 1 Flash ID: NAND blocks 0-996 Total Size: 124.6 MB Memory Map: NAND Blocks: 997 * 128 Kb RAM Base: 0x80000000 IRAM Base: 0x5C000000 OS Range: 2 - 137 File System: Memory Map: 138 - 979 Sectors: 842 Branding: VendorID: 302 OS Version: 4.0.0.206 Hardware ID: 0x84000E07 RIM BlackBerry Device Supported Bands: 0x0000FFFF Metrics Version: 3.16 FS Code Version: 10.0.0.0 FAT Code Version: 2.15 Package Version: "4.0.0.206" Build Date: Feb 27 2009 Build Time: 17:39:51 Build User: absadmin SV Number: 0 OS Address: 0x80000000-0x810F7393 App Start: 0x8063A038 Companion Binary: 0.0.0.0 RAM usage: 0x8703FFFC-0x877AFFFC IRAM End: 0xD0F90068 DSP ROM2 Address: *not present* OS Extended Addr: 0x80C78BE4 LDR Blocks: 0x80D6044C API Checksum: 0x00000000 JumpTable (<3): 0x80000300 JumpTable (>2): 0x80001E48 Radio Code: Janus radio code linked OS API Version: 109.26 STP Protocol Ver: 5.133.4 (release OS) HWV: Board Revision 0001 - [0x0C - 0xFF], 0x01 Board Sub-revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0xE7 - 0xE7], 0x01 CPU Version 0002 - [0xEA - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x02], 0x01 Power Mgt Hardware 0007 - [0x23 - 0xFF], 0x01 Version Table: OS API Version: 109.26 STP protocol version: 5.133.4 BlockFS API Version: 10.0.0.0 USB driver version: 02.01 FAT FS Version: 2.15 Block map version: 2.3 WLAN radio version: 2.4.0.83 Kernel Version: 1.10.0.252 Hardware ID: 0x84000E07 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Feb 27 2009 Build Time: 16:06:11 Build User: SCM App: Version: 4.6.0.247 Metrics Version: 1.6 Build Date: Feb 27 2009 Build Time: 18:44:14 Build User: RIM Memory Map: 0x8063A038-0x80C78BE3 App c_main: 0x807AE6C4 API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 AppFSVersion: 3.0.0.0 AppFSSize: 0x3D00000 OS API Version: 109.26 RAM Map: 0x8703FFDC-0x87040000 IRAM Map: Unused App Type: JVM Done. |
09-30-2009, 18:35 | #8 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Scotland Age: 51
Member: 933132 Status: Offline Thanks Meter: 147 | No idea what the previous replies meant, but on my 9500 you just go into Options-->Language and text input-->Keyboard Layout It gives me the choice of qwerty, qwertz, azerty |
The Following User Says Thank You to kriptikchicken For This Useful Post: |
11-24-2009, 01:41 | #9 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Proxxon
Member: 63577 Status: Offline Thanks Meter: 359 | Keyboard layout change !!!! YES can be done !!!! MODELS SUPORTED: 8100,8110,8120,8310,8320,8300,8800,8820,9000 (only this phone where can be loaded MFI ) QWERTZ >> QWERTY AZERTY >> QWERTY QWERTY>> AZERTY QWERTY>>QWERTZ AZERTY>>QWERTZ QWERTZ>>AZERTY and any other options need HAMACHI+USBoverNETWORK installed and contact me on PM |
11-24-2009, 15:29 | #10 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Riyadh, KSA Age: 43
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | Quote:
regards | |
02-05-2010, 18:32 | #15 (permalink) |
Freak Poster Join Date: May 2007 Location: Romania
Member: 513613 Status: Offline Thanks Meter: 25 | I need solution as well for a bold, and I don't expect it for free. I already PM'd sdtv team still no answer. Hope they answer eventually, meanwhile i'm trying some stuff myself. |
help... how to change bb from qwertz to qwerty keypad | freakyass | BlackBerry (RIM) | 2 | 01-04-2011 17:06 |
BLACKBERRY Keyboard Layout change QWERTY QWERTZ AZERTY | sdtv13 | Main Sales Section | 0 | 11-27-2009 14:33 |
QWERTZ to QWERTY conversion? | satria_wr | BlackBerry (RIM) | 0 | 02-09-2009 02:38 |
