BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
12-08-2008, 04:58 | #1 (permalink) |
Junior Member Join Date: Apr 2007
Member: 491368 Status: Offline Thanks Meter: 4 | Need help for MFI multiloader I have a problem. When I run MFI multiloader, it always show me a error, said " Update failed: Could not find a part of the path'T:\RMA\MML\Update.xml source:mscorlib And my computer has installed .net framework 3 and 2.0 service pack 1, I can not install .net framework 2.0. I want to know if I need uninstall .net framework 3 and 2.0 service pack 1, then install .net framework 2.0. Thanks |
12-08-2008, 05:03 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
open configuration.xml file in Notepad from Configuration folder and find the line "T:\RMA\MML\Update.xml" and change it to "C:\MML\Update\Update.xml" and your problem will be solved no more this error. Take Care ENJOY | |
12-09-2008, 07:30 | #4 (permalink) |
Insane Poster Join Date: Jan 2007
Member: 435214 Status: Offline Thanks Meter: 1 | help blackberry software Now there's another error q q I get what I put on the forum. vhgsm --------------------------- Updater --------------------------- Update failed: Could not find a part of the path 'C:\MML\Update\Update.xml\update.xml'. Source: mscorlib --------------------------- Aceptar --------------------------- |
12-09-2008, 07:35 | #5 (permalink) | |
Your Path is: C:\MML\Update\update.xml\update.xml Take Care ENJOY | |
The Following User Says Thank You to imran_qasim For This Useful Post: |
12-09-2008, 07:47 | #6 (permalink) |
No Life Poster Join Date: May 2005 Location: CellcomEngineering Age: 42
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | close all network................. and internet also..... solve this problem.......... BR. Shohag |
The Following 2 Users Say Thank You to shohag For This Useful Post: |
08-12-2009, 05:46 | #8 (permalink) | |
Junior Member Join Date: Sep 2008
Member: 853153 Status: Offline Thanks Meter: 0 | Quote:
Open your configuration file in notepad. whereever you see T:\RMA\MML\Update.xml change it to C:\MML\Update\Update.xml if it still wont work, open your update.xml file in note pad to. and make the same changes. | |
Help with MFI Multiloader? | Why_Its_Me | BlackBerry (RIM) | 3 | 05-04-2009 14:26 |
Need help about MFI multiloader | zeerik | BlackBerry (RIM) | 2 | 03-15-2009 20:08 |
ALL LINKE DEAD TO DOUNLOWEDall parts for MFI MULTILOADER | malpinssa | BlackBerry (RIM) | 3 | 12-28-2008 12:42 |
help you MFI MULTILOADER | omar_peligro | BlackBerry (RIM) | 2 | 12-10-2008 06:50 |
help you MFI MULTILOADER | omar_peligro | BlackBerry (RIM) | 1 | 12-06-2008 14:07 |
