Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 06-10-2009, 10:13   #1 (permalink)
/FAISAL/'s Avatar
Member: 781860
Thanks Meter: 203
PC not detecting 8100 blackberry mass storage device
I am using 8100 blackberry device with latest version 4.5 but my computer does not detects mass storage device.
followed below steps... no luck
Installed 4.5
installed DM 4.6
Installed latest software on PC of 8100 4.5
formatted the media card using blackberry device.
formatted the media card using Card reader(from PC)
It is not showing any removable device in device manager.
On blackberry settings are :-
Media Card support: On
Encryption Mode:None
Mass storage Mode support: On
Auto enable Mass Storage Mode When connected: prompt.
changed all possible settings no luck...
Media card is working fine if i use with different card reader.
and also it works fine with the blackberry device.( i am able to store pic)
also if i plug different blackberry device to my laptop, it will detect the memory card.
and also trying removing version4.5 to installed version 4.2 no luck.
i am facing this problem after unlocking the blackberry device...
please suggest me what else can be done....
Old 06-10-2009, 14:03   #2 (permalink)
Member: 595700
Sonork: 100.1582336
Thanks Meter: 262
blackberry not detecting solution
hi bro,
connect ur blackberry wedout batery ang hold power or callend button.
when software say connecting device than insert batery keep holding the button till fone detect ..
may be help u.....
Old 06-10-2009, 15:27   #3 (permalink)
Member: 253600
Faisal,
From my experience, if you unlocked your 8100 using MFI and especially if loaded the debranded VSM(09712-002) you will need to re enable Mass Media Storage in the 'Engineering Screen' of the bb. If Mass Storage IS enabled in Card settings under options, but is not working for you, it is most likely a internally disabled feature that can be re-activated in the 'escreen'. This is a fairly simple process...drop me a line if you need help with that. There used to be some fix/patch for this floating around the web, but it is, IMHO, safer to do it via eng. screen..
Old 02-24-2010, 19:14   #4 (permalink)
Member: 769748
Thanks Meter: 5
Originally Posted by gilnfld View Post
Faisal,
can u share in here sir???
Old 02-25-2010, 09:38   #5 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
Download VSM-09712-002
Delower
Old 02-25-2010, 17:05   #6 (permalink)
Member: 769748
Thanks Meter: 5
thanks sir, but not these because my phone cant not detect memory after im load this vsm, his say ,hi can repair this wrong by escreen
thanks
Old 02-25-2010, 17:25   #7 (permalink)
Member: 769748
Thanks Meter: 5
Faisal,
this is solution, can u tel me step by step
Old 02-26-2010, 03:20   #8 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
thanks
Its not clear for me.
Did u chk all setting or did u format the media card after load OS ?
Also try with higher version DM.
Delower
Old 02-26-2010, 16:16   #9 (permalink)
chezral's Avatar
Member: 203715
Thanks Meter: 227
Try using [BB Mass Storage Activator.bat]
Should be found on this forum with search.
Old 03-03-2010, 14:20   #10 (permalink)
Member: 769748
Thanks Meter: 5
CAN u share in here sir... please...
Old 03-03-2010, 14:45   #11 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
Here ur answer
http://forum.gsmhosting.com/vbb/show...&postcount=380
Delower
The Following User Says Thank You to delower10 For This Useful Post:
Old 03-04-2010, 04:29   #12 (permalink)
Member: 769748
Thanks Meter: 5
Originally Posted by delower10 View Post
but not working for my blackberry bold sir, what u know other trick sir
Old 03-04-2010, 11:15   #13 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
Plug in BB.
Right Click My Computer
Click Manage
Click Disk Management
Look at the right hand side and find your BB's media card and change the drive to something obscure like X or V-anything that is not common. Everything should work fine now.
PS: otherwise u have to reload another OS
Delower
blackberry mass storage erro in unlocking worldwidemovil FuriousGold 5 10-29-2009 10:02
2 BlackBerry 8100 not detected by MFI Multiloader, but they can be detected by loader -luigi- BlackBerry (RIM) 20 08-27-2009 18:22
cannot detect mass storage... dyepoi BlackBerry (RIM) 2 07-24-2009 08:16
p990 conect pc mass storage ismabdi SETool2 0 03-14-2009 07:48
PC not detecting my phone Simonee Motorola P2k 6 04-27-2007 07:45
Page generated in 0.24787 seconds with 9 queries
