Ramjan help 4 Attachment(s) I tried to update 8220 and ended up with Error 507,i didnot back up and my son coul not even remember software version , i got the firmware but still cant load and ended up into fatal error as decribed by the pictures |
my advice change usb cable and try again it will be Done! And follow this Procedure |
i followed the procedure but came with the same error on display (Reload software :507) |
first be sure you have full battery if error again update again use desktop manager |
Basically your phone was wiped before you got it and now uninstall the OS reboot pc then install other OS & make flash |
Hello sir did u have any tool to unlock iphone 3.1.3 version please post me sir |
1 Attachment(s) Delower10 that's right i got the fone while it was already wiped out, now you say i have to remove and install other os, which tool to use to install other os cause i have these two firmmwares. |
To uninstall OS go (Start > control panel > add or remove ) u will see here which OS u have installed To install OS just double click at (which u want to install ) & procedure inside |
which is the right firmware to load to this fone at this point with this error Reload software 507 |
Actually the owner has told me that the BB 8220 is from T-mobile U.S.A |
don't forget to delete vendor |
may you do me a favour by uploading this firmware at rapid share for easy download cause my speed is too slow |
help me...my bb 8320, it works fine basically, it's just that the speaker is so low, people can not hear me clearly..i've no idea how to fix it. a lot of times people i called just keep saying 'hallo' coz they cannot hear me speaking..any idea? |
May someone give me a link not the official website but something like Rapidshare website where i may download this blackberry 8220 pearl firmware:(8220M_PBr4.6.0_rel520_PL4.1.0.100_A4.6.0 .305_AVEA.exe) |
