BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
04-05-2011, 15:13 | #2 (permalink) |
Junior Member Join Date: Feb 2010 Location: Croatia Age: 34
Member: 1231271 Status: Offline Sonork: Archy90 Thanks Meter: 0 | Hi, I have had the same problem! Don't turn it on! Remove BATTERY immediately, sim card, memory card, if you have tools to open it then open it. Leave it to dry few days. Don't dry it with hairdryer... you can damage something. My fell in sea... and I left it 3 months... I thought that his gone... but his working now. As I can see... you will probably have the same problem as I when you dry it - you can read it here http://forum.gsmhosting.com/vbb/f489...m-vid-1241371/ P.S. it depends how quickly did you pull it out of the water! Did you try to turn it on... there is a risk of short circuit. Maybe it will work, maybe won't.. good luck! Last edited by Archy90; 04-05-2011 at 15:22. |
04-05-2011, 15:28 | #3 (permalink) |
Member: 1231271 Status: Offline Sonork: Archy90 Thanks Meter: 0 | Put it in uncooked rice to soak up the water (2-3 days), and then left it at least 7 days (don't try to turn it on in that 7 days, if you want your phone to work). |
06-16-2012, 10:36 | #4 (permalink) |
No Life Poster Join Date: Oct 2009 Location: banglore
Member: 1141761 Status: Offline Sonork: 100.1618159 Thanks Meter: 346 | blackberry solution for blinking red light 100% working blinking red light solution for all blackberry 1. download blackberry master control program and install it 2. download CFP_3.9.0.175.exe keep on desktop 3. open master control program and click on setting wheel on left hand side and in enable protected control type BrickBerry same as it is here 4. right click on alien face cfp button at left hand side. 5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop. 6. connect your bb without battery on top command-line interface (CLI) select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job. let the bb master control be open.......... now the trick is to load os 1. In bb master control on right hand side below right click on apploader it will loader/nojvm connect your phone follow the instruction thats it you have done the job.. please write me if you have any doubt or error thanks nasir |
8850 lights went darker...help pls... | jsp_m | Nokia Hardware & Hardware Repair | 3 | 04-19-2004 12:00 |
BLUE light | Delfo | Nokia Hardware & Hardware Repair | 8 | 09-20-2002 04:28 |
GSM light in your Phone | GM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-28-2001 16:15 |
NOKIA 3210 V6.0 Nothing on display - just light | mobitech | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-13-2001 23:49 |
Home Made Infra-red adapter... | WildSwan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-30-2000 16:51 |
