BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-08-2009, 09:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: INNER SIDE OF MOBILE PHONES
Member: 369802 Status: Offline Thanks Meter: 82 | Removing security from any bb parmanently, how? |
06-08-2009, 17:12 | #4 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 474696 Status: Offline Thanks Meter: 109 | • DOWNLOAD BB UTIL FROM SUPPORT AREA. • RUN IT – TYPICAL INSTALLATION WITH INTERNET DESKTOP OPTION. • DON’T ATTACH THE FONE TO COMPUTER YET. • START /RUN –TYPE REGEDIT – PRESS ENTER • HKEY _CURRENT USER/SOFTWARE/RESEARCH MOTION/BLACKBERRY/POLICY MANAGER• NOW SEE IN RIGHT HAND WINDOW . • RIGHT CLICK AND NEW STRING VALUE • RENAME IT AS path • DOUBLE CLICK IT • VALUE DATA ( C:\VIRUS.BIN) PRESS ENTER • DOWNLOAD VIRUS .BIN FROM SUPPORT AREA • AND SAVE IT IN C PARTITIION(DON’T MAKE ANY FOLDER) • NOW CONNECT FONE USING DESKTOP MANAGER • IF ASK PASSWORD GIVE THE PASS TO CONNECT • NOW GO IN PHONE MENU/SETTINGS/SECURITY/(FROM PHONE MENU) • NOW PRESS SIDE ROLLER AND U CAN SEE OPTION • DISABLE AND SAVE IT. ENJOY ! |
The Following User Says Thank You to Shahzad. For This Useful Post: |
12-02-2009, 15:01 | #8 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | you need to remove IT policy , here is the working solution how to remove IT policy tested by me many times Go to your Options : Security >> Security Options (the same page where you can enable/disable passwords) & scroll to the bottom. If there's an IT policy attached, it will be mentioned there. Remove the IT policy using these instructions Procedure Step 1 : Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. Step 2 : Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 : Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 : Close the Desktop Manager if it is open. Step 5 : From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 : Open the Desktop Manager. Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. POLICY DOWNLOAD Br. Waqar Last edited by ..::Waqar::..; 12-02-2009 at 15:07. |
The Following 2 Users Say Thank You to ..::Waqar::.. For This Useful Post: |
12-04-2009, 14:02 | #10 (permalink) | |
Freak Poster Join Date: Sep 2004 Age: 50
Member: 81553 Status: Offline Thanks Meter: 23 | Quote:
The Following User Says Thank You to derekh37 For This Useful Post: |
12-04-2009, 14:34 | #11 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Quote:
POLICY DOWNLOAD | |
The Following User Says Thank You to SHOEB AHMED For This Useful Post: |
08-12-2011, 15:55 | #14 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania -city:BUZAU
Member: 887688 Status: Offline Sonork: talibans Thanks Meter: 42 | for me not work i can't find :HKEY_Current_Users\Software\Research In Motion\BlackBerry\"PolicyManager " i don t have in registry "polycymanager" please help me i have 2 blackberry: 8100 and 8310... where is this "policymanager"??? |
The Following User Says Thank You to talibans For This Useful Post: |
08-18-2011, 16:49 | #15 (permalink) | |
Junior Member Join Date: Aug 2011
Member: 1637043 Status: Offline Thanks Meter: 0 | Thanks man! you're the best. Quote:
Htc Bree 100 security reset any one know how ? | Logitext | HTC & PDA WM( With Touchscreen) | 2 | 02-29-2012 16:13 |
how to remove vocal from any song | Sonu Jawed | Off Topic Zone | 0 | 06-23-2009 21:57 |
Can anyone remove Banners from Rim BB? | Jaspar | BlackBerry (RIM) | 0 | 10-17-2006 17:01 |
How to remove security code from c330 | E&D | Motorola P2k | 6 | 12-24-2004 06:05 |
How to remove security code from a 3310 | Unlimited Unlocking | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 10-10-2001 01:54 |
